Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Dryer I have a 2002 Maytag Stacked Washer/Dryer and one of the three paddles in the drum of the dryer has come off. Please advise how to repair this.
  • 943 Answers
Hi thanks for the question. the top of the dryer comes off. revealing the screws that hold the baffles in place . re- install the baffle, and the top. thanks the appliance doc.
Posted on Oct 06, 2008
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
I HAVE A MAYTAG NEPTUNE GAS DRYER MODEL 3MDE3000AYE. ONE OF THE THREE PADDLES INSIDE THE DRUM CAME OFF. I AM TRYING TO REATTACH IT TO THE DRUM, BUT THE SCREWS HOLDING THE PADDLE ARE INSIDE THE DRUM.
unplug the dryer,open the door,remove the two screws holding the door on and remove the other two screws opposite them,take off the door and pull the front panel off,spin the drum until the baffle you are trying to repair is in the bottom right hand corner and you can get at it like that
Mar 13, 2010 | Dryers
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Dryer tries to start but drum wont turn
You can turn it by hand but make sure it is unplugged!!
Jun 28, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
I have a coin in the paddle of the dryer
The following is the link to the internal diagrams to your model, might help you in disassembling.
click here for internal diagrams
The link has few models with the same model number, choose your model and i hope it works out.If there is anything else i can help you with, then please do post comments.Good luck.
Jan 23, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
