Question about Nokia 6120
6120 USB Connection
The Get Connected Wizard on my 6120 is not registering any connection. My phone comes up as new hardware on my PC when plugged in and I am using a DKE-2 USB. The phone comes up with PC Suite on the screen when it is plugged in, but then the wizard does not register it is there. Is there a way around this? Thankyou
  • Nokia Master
  • 1,800 Answers
Chek the device manager and see if ur phone in modems .. got the small yellow piont if so that means u shud reinstall the driver of ur phone or the cable
plz do rate this post as good as u can!!
Posted on Oct 06, 2008
I have tried in vain to get the USB connection on my Westell 6100 to work. Are there some tricks to making this happen? The ethernet connection will work fine, but I cannot get the USB setup to work at...
I suggest that you use ethernet connection instead of the USB connection.
Ethernet is more stable that USB, you less likely to experience dropped connections.
Also take note that you can only use one connection at a time. You CANNOT use Ethernet on one computer, then USB on the other computer.
But if you insist to use the USB connection, you need to install the drivers. Once the usb cable is connected to the modem and computer, you will get a found new hardware wizard screen. Then you will need to insert the CD that came with the adapter to your computer.
If the found new hardware wizard did not appear, check your device manager and look if there is a USB adapter with a question mark or exclamation point. Right click on the USB adapter then click reinstall.
It should detect the drivers from the cd.
Good luck and have a great day!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
No Phone Connected
you need to switch to the correct mode on the fone first (menu connectivity - usb connection)
Feb 03, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
My LG Viewty will not connect to my PC
make sure the phone is on data transfer (in phone settings - connectivity - usb connexion) if your using the lg suite.... plug the phone in first (to USB cable) then start the pc suite ,, if nothing... try using the connection wizard thing ,, it will search for connected phones.
Jan 13, 2009 | LG KU990 Viewty
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
How to download from pc to motorola v170
just connect your unit to the pc by usb cable compatible to your unit, then the computer processing recognizing the unit plugged  and wizard pop up, if your pc have ready install driver it will automatically installing unit prompting wizard "the hardware is ready to use", goto my computer double click shows pop up windows  feature hard drive and other devices connected then by there you view the drive for your unit, double click just like opening folder and you can start.
if, however pc didn't recognize you have to do manually by going to control panel click add hardware then wizard will guide you and prepare for your cd installer for the driver, this comes with the product you purchased.
Oct 19, 2008 | LG KG320 Cellular Phone
Failing connection to phone via USB
Hi, I just had the exact same problem..
I tried like FOREVER and I even said, if this try doesnt work; i'm giving up, and then... it finally worked.. haha :) so, this is what I did.
(dont connect your phone yet but set your phone as data service) You open the program LG pc suite, and then click connection wizard > usb > and then here, you connect the both ends of the usb.. one end on your pc and the other on your phone, and then you press next. Hopefully it says something like Com Port Number and Phone Model. You click next and finish. So, now you are connected to the phone to your pc. To get photos to your pc, you click content. images. and copy and paste to where you like (pictures in your pc) and then your done :D this also goes to other files too :D
I hope this really helped because I just learned it few minutes ago and I was about to scream because I tried so many ways. Hope this helped and Good Luck :D
Jul 22, 2008 | LG KU990 Viewty
Lg veiwty
First connect the phone using the USB cable provided.
Open the LG PC Suite software. On the left hand side is a connection wizard select this and then USB.
Don't change any of the port information.
Once it has connected, select contents.
go to your picture folder and then just drag your pictures onto it.
DONE!
May 29, 2008 | LG KU990 Viewty
Phone model sony ericsson w900I problem :- after cd software installation and phone USB connection and the cable bells out correctly the pc won't see the phone connected. The phone knows it is connected...
Did you restart your computer after software install?
Sometimes you need to restart if you just installed the software WITH the phone plugged in at your usb port.
You may try the windows trouble shooter by clicking the start then control panel then printers and other hardware then scanners and cameras then on the left under imaging tasks click "add an imaging device" then the "camera and imaging device" wizard window will come up. From there select the "have a disc button". Place your disc in cd rom drive and click o.k.
After you have done this you will have to restart your computer also, in some instances.
Try these two things and let me know how it worked.
These instructions may vary because these instructions are for windows xp hoome.
Apr 15, 2008 | Cell Phones
To know my the free download software of my phone
For those who are having connection problem with moto
Step 1. Get the software
Go to Motodev and download Motorola USB Driver (you will need to register)
Also download your chosen p2k program e.g. p2kMan
It would also be a good idea to locate RSD Lite – you will have to use Google to find this as it is classed as warez and we cannot give
links.
Step 2. Install the driver program
Extract the file “Motorola_EU_Driver_Installation.msi” from the zip file you downloaded.
Double click on this file and the installation will start.
Click next and the EULA will appear
Click on "I Agree" (obviously having read the agreement first Angel), then next.
The program will now install
Click close to end the install procedure
During the installation process you may see the following screen 1 or
more times
Should this appear hit "Continue Anyway"
Step 3: Install the drivers
You will now have a new program group in your start>programs menu -"Motorola Driver Installer", with a shortcut called "Motorola Driver Installer.exe" within it.
Make sure the phone is disconnected at this time.
Run this program, and it will check whether the drivers are already
installed, when this is complete you will see the following screen
Under "Operation Mode" (lower left), select "Clean and Reinstall" (the bottom option).
Then hit "Start"
The program will then do its thing. When it is finished hit "Exit"
You may get the message about Windows Logo testing again - if you do hit "Continue Anyway"
Step 4: Connect the phone
Make sure the phone is turned on then connect the USB cable. It is best
to use a USB port on the rear of the PC rather than front mounted ports
as these sometimes connect to the motherboard via a hub
When you plug the phone in Windows will find new hardware - Motorola
Phone (V3), then Motorola USB Modem. The installation should
complete without intervention.
You should now be able to connect using Mobile Phone Tools, the phone
should also be charging.
We now want to install the P2k Drivers. First make sure MPT is not
running.
Now with the phone still connected run one of the P2k programs, I generally use P2kMan - but thats just me. Its best not to use p2k Tools as this may start in AT mode and confuse matters.
When you do this Windows should find several new devices and after a
short while the new hardware wizard will run. In the rare event the new
hardware wizard does not start, install and run RSD Lite.
The first screen to appear asks if you wish to connect to Windows Update
Select "No, not this time", then click on "Next"
Choose "Install the software automatically (Recommended)", then hit "Next"
The driver for Accessories Interface is then installed, after a short
while the following screen is displayed
Click "Finish"
The new hardware wizard will then run again
Once again select "No, not this time", then click on "Next"
This time the wizard asks for drivers for "Data Logging MCU Interface".
"Next"
Again the drivers are installed then after a short while the
following screen is displayed.
Click "Finish"
The new hardware wizard will then run for a third time
At the first screen select "No, not this time", then click on "Next" in the same way as before
This time the wizard asks for drivers for "Test Command Interface".
Again the drivers are installed then after a short while the following screen
is displayed.
Click "Finish"
Your P2k drivers are now installed and the P2k programs should
recognise the phone
Remember if you connect using a different USB port in the future,
Windows will recognise new hardware and you will need to repeat these
steps
Step 5: Flash Interface Device
If at anytime you choose to flash your phone you will need the Flash
Interface device installed. This device is used to communicate with the
phone while it is in bootloader mode.
In order to run the hardware installation wizard for this device you
can do one of two things. Either use RSD Lite to flash the phone as
normal (browse to the file and hit start) and RSD Lite will switch the
phone to bootloader mode for you. Alternatively you can start in
bootloader manually (hold * and # while turning the phone on), then
Either way the new hardware wizard will run again.
As before select "No, not this time", then click on "Next"
"Next"
is displayed.
Click "Finish" and you are done - you can now flash your phone with RSD
Lite.
Once more remember if you connect using a different USB port in the
future, Windows will recognise new hardware and you will need to repeat these steps
Nov 28, 2007 | Motorola Mobility RAZR V3
Samsung u600 usb connection wizard
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Oct 24, 2007 | Computers & Internet
Nokia 6120 Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
