Question about Philips Televison & Video
I own a Philips 42PFP5532D plasma television, and when i plug the 3.5 headphone jack into the back of the TV. i can barely hear sound through the headphones and i can still hear it through the TV. i only want to hear the sound through the headphones, thanks
  • 65 Answers
SOURCE: Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Posted on Dec 09, 2006
Shuttle83
  • 1139 Answers
SOURCE: No sound from a Philips model 60P8341...
Hello Jarvis1,
This is an indication that the actual sound output is working, but the amplifiers to the speakers are not. How you could take care of this is to check in there are any loose connections to the speakers. Then check if you have sound coming from the leads of the output stereo amplifier (You will need the schematic and an audio tracer/tracker to find this location and test for sound). I would venture that there would be no sound from the amplifier. If not you will have to replace the amplifier chip. I would suggest getting a qualified TV technician to perform this task. If you do have sound at the output of the strereo amplifier chip, then it might be a case of the earphone jack switch being broken, let me explain when you plug in your earphone the speakers are disconnected by a switch in the earphone jack if this switch is broken it could disable the speakers and produce these results. There is also the possibility that you have the speaks disabled from the menu of your TV (check this too, actually check this first).
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 04, 2008
  • 4234 Answers
SOURCE: Hi , Got a philips
If the unit is only 8 months old, it should still be under warranty. don't waste your time. Return it for warranty service.
Dan
Posted on Jul 30, 2008
  • 44 Answers
SOURCE: i have surround sound stereo
You'll need an Audio Out connection on the tv for surround to work properly. The signal level and the impedence mismatch of a headphones jack would not work or work poorly.
Posted on Aug 22, 2008
SOURCE: Hi. I recently purchased an
No when you plug in the headphone the tv auto mutes
Posted on Sep 10, 2008
Have an Hitachi 42 PMA400e Plasma Tv.
Unfortunately, if there is no headphone connector on the TV there is no practical way of accomplishing the alternate arrangement.
Mar 21, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Televison & Video
The TV has absolutely no volume, except if you are using headphones
Hi satisfy_2liv,
The fault was came from the headphone jack itself, when you connect the headset to this jack, it will open the internal contact to the speaker of the TV and you will hear the sound only in the headset. But the problem is, it will not get back to contact once you pull-out the headset to return the audio signal to the speakers. This may probably has a dirty contact or totally faulty. Bad solder joints is also to consider in that area. First you may spray contact cleaner to the jack while inserting and pulling the headset plug. If symptom still persist, check the board for bad solder joints. If the joints isn't the problem,replaced the earphone jack and your unit will back to normal again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 31, 2011 | Philips Magnavox 27MS343S 27" TV
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
We have a Sanyo DP19649 and headphones dont work
Turn speakers off in sound menu if available. Then turn up volume to hear in headphones.
May 06, 2010 | Sanyo DP19648 19 in. LCD TV
Philips 42PFP5532D/ MAKES THE NORMAL CLICKING NOISE WHEN YOU TURN IT ON . BUT IT CLICKS BACK OF AGAIN SO YOU DONT EVEN GET A PICTURE ALL YOU GET IS THE RED STANDBYE LIGHT FLASHING DO YOU NO WHAT THE...
philips tv's test them selves when turned on if something is wrong it shuts down you need a tech to determine your problem more than likely it is you power supply
Sep 18, 2009 | Philips 42PFP5332D 42 in. Plasma...
Audio not coming out input 3 in
input to the tv is incorrect select av3 0r what ever the front jack is marked on you tv. good luck farr64
Apr 30, 2009 | Mitsubishi WD-73735 Television
TV has no sound
Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
Nov 18, 2007 | Philips 25PS40S 25" TV
No sound
Check first if theres a speaker cutoff in the menu of the set or the back of the set. Next see if theres a headphone jack and plug in a set of phones to see if you get sound. If you do a connection on the jack is bad. if you put youe ear right next to the speaker and hear a little background noise or a little sound then its probably in the volume control curcuit. if you hear nothing at all its the audio output IC or the speaker itself is defective. Good Luck
May 17, 2006 | Philips 21PT6818 21 in. TV/DVD Combo
Televison & Video Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
