Question about NEC HT1100 Multimedia Projector
Issues with NEC HT1100 display when using DVI-D connector
Hello. I have a NEC HT1100 projector and am using a Sharp BD-HP20U Blu-ray player. I recently purchased a Steren HDMI to DVI-D cable (30 foot) rather than using comp cable; however, though the projector's manual states the projector will disply up to 1080i via DVI, I get static when anything above 480p is selected on my blu-ray. I've disconneted and reconnected the cable, ran the cable straight from the bluray to the projector versus routing through my receiver (this actually made the static worse), and tried adjusting eveything I could through both my player and projector. Can you give a frustrated guy some advice?
SOURCE: I am using a NEC
its a common problem of the video hardware in the laptop - it hasnt the ability to split the video "overlay" (often its decoded by something in the video chip, or at least a seperate bit of software and output seperate from the usual, slower windows & images data stream) off to the second screen & you just see the frame of the player.
if you set the external output to be the main/primary, or sometimes only active screen, it should work. you might also have a chance if you make it an extended desktop rather than a cloned one, then moving the player window entirely onto the projector's "screen"
Posted on Jul 02, 2008
maklean
  • 1665 Answers
SOURCE: nec gt5000 projector turns off 10 seconds after power up
It;s power supply circuit seem to be faulty.
Posted on Sep 13, 2008
SOURCE: My NEC MT 1050 projector
when i on the projector is rotated how do i fix it bk
Posted on Oct 08, 2008
SOURCE: pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Posted on Oct 20, 2008
RyanFanMan
  • 342 Answers
SOURCE: mt1065 NEC projector HDMI to DVI adapter no
did you buy that adapter from radio shack if so then return it and look at somewhere like staples or best buy they can help you
Posted on Jan 02, 2011
My sharp blu ray player no longer plays blu rays
If it plays CDs and DVDs but not BluRays at all, then the blue laser is burned out. CDs and DVDs use a different laser. A needed firmware update would not prevent it from reading a BluRay.
Aug 06, 2014 | Sharp Bd-hp20u Blu-ray Player
IS THERE A WAY TO HOOK ETHERNET TO A SHARP BR MODEL BD-HP20U
You can connect it by any way to your BDP. There are cables to connect in between. HDMI, S-Video & AV. After connecting these cables with your TV, select the appropriate selection to video by TV.
Jun 01, 2012 | Sharp AQUOS Blu-ray Disc Player
Projector Input is on DVI - Video. HDMI cable thru an adapter is plugged into DVI port. When av receiver has "TV" selected; Picture is projected. When Blu-Ray is selected; there is no picture....
The Sharp XR-30X will display 720P and 1080i. The Blu-Ray player is trying to send 1080P which requires a handshake. It sounds like you might have to go into the Blu-Ray player and tell it to use 1080i.
Mar 04, 2011 | Sharp XR-30X Projector
I have the aquos bd-hp20u and i cant find the update anywhere.... help!
just go to www.blu-ray.com/firmware. before you download, make sure you have selected the correct country location you are in now.
Sep 16, 2009 | Sharp BDHP20U Blu-Ray Player
Australian region code
Australia and new zealand DVD playes usually are region 4 only this means the DVD is probably imported. You will need a multizone DVD player to watch it.
region A = region 1
region B = region 2
etc etc
Hope i could help
CBZ
Comment if you need more assistance
Apr 28, 2009 | Sharp BDHP20U Blu-Ray Player
Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
Dec 25, 2008 | Televison & Video
Disc is stuck in my sharp bd-hp20u
Look below the bd/dvd door where you load your disks you will fine a tine hole there. Find a narrow screwdriver around 4 to 5 inches and poke it into the hole there is a mechanical lever that will release the tray assy and unchuck your disks without damage to it.
Oct 01, 2008 | Sharp Televison & Video
I have a BD-HP20U Blu-ray disc player. I have downloaded the software update but the player will not recognize the file on the USB device. I have followed the directions very closely and have re-tried...
I had the same experience, trying several different USB sticks with different capacities to see if it would make a difference.
What DID make a difference was resetting the BD-HP20U to factory settings, and THEN installing the update from the USB stick. This time, the unit recognized the file on the USB device and installed the update.
Apr 12, 2008 | Sharp Televison & Video
NEC HT1100 Multimedia Projector Logo
67 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
