Question about Polaroid FLM-2625 26 in. HD-Ready LCD Television
Polaroid model TDA 02610C
A black rectangle appears on the screen after the tv is on for a short time. The rectangle covers a little less than half of the screen. It may or may not disappear in a few minutes. It disappears if the TV or the cable box is turned off and back on. It may then pop up again. We purchased this unit a few months ago and it has worked well up to a couple of weeks ago.
Joe Singerman
email: singjoem@gmail.com
phone: 985-370-5523
PS: what is the telephone number that the instruction manual says can be found next to a telephone icon?
  • cblackburn1 Nov 11, 2008
    I get the same black box on my tv. Usually it will have some sort of numbers and symbols. But now it's only a black box. It will not go away unless I turn the tv off and back on. Then after 30 seconds or so it comes up again.
  • 374 Answers
Joe from what you describe it sounds as if the closed captioning display is turning on either through the tv or cable box if your's has that capability. Go to the menu on the tv and go to the setup option, from there you should be able to locate the closed captioning option and turn it off or disable it. The same may need to be done with your cable box if it is closed captioning compatible. I hope this is of some assistance to you. If I can help in anyway please let me know.
Posted on Oct 06, 2008
Black screen
You may have blown power supply for the backlight inverter or blown backlight inverter board, either one are cheap!,
This is cheaply made TV to begin with. Repiar shop will charge you $200 and up plus parts.
http://www.shopjimmy.com/catalogsearch/result/index/?q=Polaroid+TDA-03211C+&limit=100&p=2
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid HD TV 32" Black square in the center of the screen,
Is your closed caption selected? I saw the same problem with my friend's Sansui HDTV.
Jan 18, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Black Rectangle on Bottom of Screen
It is your Closed Captioning malfunctioning. You can try and access the menu and turn the CC off but more times than not it is a malfunction that is unfixable.
Please remember to rate this solution.
Feb 13, 2009 | Curtis-Mathis CM27101S TV
Poloroid LCD HDTV w/ DVD player model # TDA-02610C manual
Here is the link for the manula you requested: http://www.polaroid.com/service/userguides/ce/lcd_tvs/tda-02610_tdx-02610_ug_en.pdf Please rate how helpful this was. Good Luck, and than you for using FixYa!
Jan 13, 2009 | Polaroid FLM-2625 26 in. HD-Ready LCD...
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black rectangle blocking view
SOUNDS LIKE U HAVE THE CLOSED CAPTIONING ON, CHECK IN YOUR MENU AND TURN OFF
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Polaroid FLM-2625 26 in. HD-Ready LCD Television Logo
310 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
