Question about HP Photosmart C5180 All-In-One InkJet Printer
C5180 all in one inkjet
Ink system failure error oxc18a0001 have tried unplugging lead from back of printer, removing cartridges replacing them after 2 mins etc etc did not help also tried holding down ok and help, removing lead switching back on this did not help either any other solutions. I only got printer in feb 08 it is not over used at all
    Sergeant:
  • 352 Answers
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 12, 2008
Ink system failure oxc18a0001 /c5180 all in one ink jet printer
This is a common problem, it is caused by air in the ink feed tubes. This happens if you allow your printer ink to fully run out and the unit sucks air or you use a poorly filled refill cartridge that has air bubbles. To clear the error you will need to do a purge on the system. The procedure takes about 10 minutes to complete. We have a step by step guide to this at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
May 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have an error code Oxc18a0001 on my HP c5180. Could you please help me? Thanks
Are you using a factory new ink cartridge?
Please consider the following before you read through the information that I obtained from the HP website.
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Issue:
An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution:
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Nov 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp ink system failure
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much. adonscott
Jul 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
62 people viewed this question
Ben Johnson
