Scanner symbol ls3070-i100US
HI. I'm looking for a driver of scanner symbol ls3070-i100US. Can you provide one, please?
  • Jere2008 Oct 16, 2008
    The Symbol (Motorola) 1.8.5 driver does NOT operate under Microsoft VISTA.
    I have contacted technical support and sales support people at Motorola and they do not have any idea when a compatible driver will be available; nor do they have any suggestions about getting their products running in the configuration needed (USB and VISTA).
    I have also been [desperately] looking for a [ANY !] solution.
  • 63 Answers
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Posted on Oct 06, 2008
Is there a way to turn scanner on and off in a motorola 9090g. It appears it is only triggered in a application. I am trying to use the bar code scanner in a web based application.
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. You can also install the application DataWedge provided by the manufacturer. The DataWedge aplication will activate the scanner and the decoded barcode is sent as usual keypad inut to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
To download the DataWedge application please go to support.symbol.com website and search for DataWedge, or use this direct link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12685
Nov 15, 2010 | Symbol MC9090-G Barcode Scanner
HI I HAVE ONE MOTOROLA SYMBOL DS6707 BARCODE READER TODAY ONE PROBLEM OCCUPIED. ANY MOBILE IMEI CODE SCAN BUT BATTERY NOT SCAN. SO PLEASE HELP ME
The EMEI Barcode and battery barcode are probably not the same length. When the scanner is set for specific length, he will accept only some barcodes.
Please check the length of the barcode. Set the scanner for two specific lengths or for any length of barcode. Try to scan again.
To set the scanner you would need programming barcodes. Those are listed in the DS6707 Reference Guide, provided at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf
Nov 04, 2010 | Symbol DS6707 Wired Barcode Scanner
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
Scan bar code using motorola MC75
there are several ways to use the scanner: you can have an application directly with scanner drivers implemented. Or you can install the application DataWedge provided by the manufacturer.
The DataWedge application will activate the scanner and the decoded barcode is sent as usual keypad input to the system. The application is running in background, so you can have your favourite simple application in foreground and scan data directly.
Jul 15, 2010 | Zebra Symbol MC75 Portable Data Collector...
LS3070 (ls3070-i000a) Handheld: My scanner stopped scanning. It beeps four times. ...
The four times beep means that there is an problem in the connection to the PC, please check the cables and configuration.
May 18, 2010 | Symbol LS3070 (ls3070-i000a) Handheld
I have a Symbol LS3070 that has stopped sending a return after UPC-A scans. I added a suffix of 7013, and got no change. Any Ideas?
Scanning Scan Options, Data Suffix, Enter from Adobe pages 141 and 142 of 214 the LS3070 Product Reference Guide resolves this issue. The suffix is already set to 7013 so scanning the barcodes above should be all you should have to do to send the return or enter key after every barcode scanned..
Nov 16, 2009 | Symbol (LS3070-I100US) Handheld
Need XP driver
You don't need an XP driver...the system uses either a USB connection, Keyboard Wedge connection or Serial connection. There are some other versions available. The 3070 memory scanner is an older version, but, doesn't use "drivers" as such. The best thing to do is contact the Symbol/Motorola Help Desk at 1-800-653-5350.
Cheers.
Billy Barcode
Apr 22, 2009 | Motorola Computers & Internet
Looking for driver for scanner benq 5000 model 6678-9Vz
Please download the exact driver after providing the information to the official website of UMAX
Here is the link: UMAX Scanner
Regards
Ellin
Oct 05, 2008 | Umax Astra 2000P Flatbed Scanner
Symbol ls3070
You can download the manual here :
http://www.gsv-service.com/download/ls3070.pdf
You're welcome, but don't just sit there clapping, throw money at me :)
Jan 21, 2008 | Symbol (LS3070-I100US) Handheld
Computers & Internet Logo
1,415 people viewed this question
David Payne
David Payne
