Question about Sunterra 450gph Pond Pump
Pump goes on and off
My pump cycles on and off. It use to run whenever plugged in and that controled the on off, of course. Now it will maybe run for 20 min or so shut down and come back on in say 3 or 4 min. I've cleaned it and checked the power source and seemed to be ok. It's not a year old
The picture looks like the Sunterra pump that came with my freeform pond kit I purchased at Aldi's 5-6 years ago, but just had installed this spring. The pond is 4 x 6 x 1 foot or so deep. The problem is the small triangular shaped filter has to be changed constantly. The pond is in the sun, has a large plant in it and 3 goldfish/koi. It used to go a day or two before clogging up, but now it's an hour. The water 'bubble' shrinks down to nothing and I'm afraid my fish aren't getting enough oxygenation to their water.
Posted on Jul 23, 2013
    Problem Solver:
  • 4 Answers
Does the pump have thermall protection? It sounds like its getting hot and tripping the thermal protection switch in the pump windings.
Posted on Nov 08, 2008
GroundFOS water pump won't stop running after replacing PVC pipes
you may have to blead air from the water lines. air pokets will not let your pump regulaet. as your pump feeds water into the filter and all your house hold pluming it must reach a set presher. if ther is air trapt in the sistem it can not build enouph back presher to force the pumps PSI regulaeter switch to ingaidge. air is lighter then water ther for thes to difrent forces pushing against one another couses a flucksuaition and can not regulaet. blead all lines from the pump to all outlets"fosets,spikets and filltering sistem. let pump run while going to all outlets one at a time opening and closeing "cold side first" them to releave the air from the lines. donot forget eny outside fosets this should solve the problem. thank you for leting me help you today .
Feb 17, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
The pump is not working. When switched on it makes a noise but does not pump. Sorry, a bit vague but would welcome any advice. Graham
it could b a few things maybe it needs primed.or maybe it has a small hole somewhere in the cycle letting air in.mayb this can help
Apr 21, 2011 | Lotus Garden
I have installed a Hunter psr22 pump start relay and connected it to a Hunter src irrigation controller and when I cycle the irrigation controller to manual all stations it will not start the pump. There...
So the mv and c are supplying power to the transformer/relay and out of it, but the pump won't start until the relay is forced.
I'm thinking the relay contacts are oxidized, and need to be cleaned. When they have oxidation, current goes up, and voltage might appear ok. If any start capacitors are in the circuit, they can be faulty, breaking down under a load, while reading ok. I haven't heard of any caps in these systems, but just in case.
The following blog may help you- it's about different controller situations:
http://forums2.gardenweb.com/forums/load/water/msg121639307045.html?9
Hunter's website has some things to check concerning the controller:
http://www.hunterindustries.com/resources/library/product_technical.html
Looks like it could be microprocessor lockup. It's quite a process, but here's what they say is the fix:
http://www.hunterindustries.com/resources/library/Technical/200611_hdln_micropro.html
Good luck, hope this helps, and thanks for using FixYa.
Sep 14, 2010 | RTO Hunter Psr-22 Pump Start Relay
Torpedo pump...I have one when I plug it in...it trips breaker
I had the exact same issue. I left mine out for the winter and when I plug it in, the breaker trips. My warranty was up so my friend took it apart. The seal had broken alowing water to leak into the bottom the pump where the wires connect to top of motor. This is supposed to be water free and is protected by several seals.
I am currenlty trying to put sealant where the cord goes into unit to stop water from going in. I will let you know how that works.
One tip my friend recommeded is to make sure there is no stress on the cord as it appears this seal is weak and and kind of stress will break it. hope this helps -- Rob
Apr 27, 2010 | RTO Cal Torpedo Pump 7500 Gph
With the water running the MQ pump runs intermittently
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Mar 09, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a grundfos mq3-35b, you turn on the tap pump goes on, then after about 30 seconds it goes off for about 10 seconds and goes back on again, this keeps repeating as long as you have the tap running,...
The control unit is faulty, I had that problem twice.. I have now bypassed the control unit and use a normal pump pressure switch to control..works fine..The Grundfos company at first said I had to have air in the lines then admitted the control assy. was at fault. after two new units in three years I did away with the control unit.
Nov 26, 2009 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Pentair whisperflo pump will not turn on
See if you can manually operate each pump. I suspect the problem is not with the pumps themselves. Track the control from the pumps to the motherboard, which I suspect. Whatever it is, it has all the pumps in common with it. Maybe just a simple control switch that is exposed to the elements.
May 04, 2009 | Garden
Pump is over heating
There are a few possibilities. Pump duty cycle, ie. how long it is designed to run at one time. Most electric motors have a code on them or say continuous or some other duty cycle range. Is your pump designed to run as long as you run it. Next is wiring, are you using the correct gauge wire for the load? A wire size too large will generally not hurt, but decrease the wire size and your wire will heat up along with the motor. Usually this can cause the breaker to pop or the motor to over heat and stop. Another wiring issue could be a short or bad connection on either end. Some 230 motor will run on one leg of voltage but less efficient. Check the connections at both ends and put a meter on them to check for shorted wires and voltage on the wires at the pump. The last thing I can think or is that you have a defective pump in some way. Perhaps a bad bearing or seal. I am not familiar with pump controls yet. I am getting one soon. I am guessing there is a start/run capacitor in it. If it starts the pump it shouldn't be the source of your problem. Assuming all equipment you have is designed to work together. Good Luck.
Mar 21, 2009 | Craftsman 1 Hp - 230v Pump Control Center
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
Sunterra 450gph Pond Pump Logo
316 people viewed this question
Top Sunterra Garden Experts
Jay Finke
Jay Finke
J.D. Browning
J.D. Browning
Are you a Sunterra Garden Expert? Answer questions, earn points and help others
