Question about Jensen TS2750J TV
12 volt 15 inch screen
Tv turns on and then goes to blue and then to black and then to Jensen screen, again and again.
Remove 12 volt power supply from tv for 1 minute. reapply power ... it should work now.... I had the same problem and this fixed it ... when I say remove power I mean totally disconnect the power from the TV
Posted on Dec 06, 2008
Crack in screen can it be fixed
Posted on Dec 05, 2008
    Champion:
  • 252 Answers
Try to resolder the tuner but be careful of short circuit.
Posted on Oct 18, 2008
I have a jensen Je 1911 dvdc, it will not stay on but 8 seconds help we have 8 days left
Jensen 19" 12-Volt TV/DVD - Camping World
www.campingworld.com > ... > TVs & Accessories > TVs
Rating: 2 - ‎2 votes - ‎$269.00 - ‎In stock
Where does one get a replacement remote for the 19 inch /dvd model ??/. 1 answer(s)... Need remote replacement for Jensen JE1911ABC. 1 answer(s).
JENSEN LCD TV Accessories - Jensen RV Direct
www.jensenrvdirect.com > Products > LCD TVs
Items 1 - 12 of 22 - We also offer video control centers, PAL tuners, and digital tuner boxes which will convert your analog TV signal into a digital one.
postheadericon JENSEN JE1914DVDC DVD STAND
dynastre.tk/469748/dvd-jensen-je1914dvdc-stand
Dec 27, 2015 | Jensen Televison & Video
Why does my Jensen TV keep looping?
try leaving off for about 15 minutes then turn back on may have a button battery for mrmory if so will need to remove for a couple minutes hand
Jun 28, 2014 | Jensen Televison & Video
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
My flat screen 12 inch sharp Tv has a black sqaure apparening when I change chennel or do anything with remote. It only goes away when pressing the vol. botton the a few minutes later show up again. please...
Your closed captioning mode is set to ON. You need to just turn that off. That setting is available through the on screen menu. Just turn closed captioning off and it will work normally again.
Apr 16, 2010 | Zenith C27A24T 27" TV
Wires
Wiring Connections
1. TV TUNER
2. ANTENNA
3. POWER ANTENNA WIRE (Blue) – Connect to a motorized (power)
antenna and/or to a remote turn-on lead for an amplifier.
4. CONSTANT POWER WIRE (Yellow) – Connect the 12V PLUS constant
power wire to a live 12 volt wire in the vehicle. Before making a connection,
check that the wire you intend to connect it to is always live, even when the
car’s ignition is turned off. If a live wire is not found, route the wire to the
car’s fuse block and connect it to a live circuit there.
5. GROUND WIRE (Black) – Securely fasten the Ground wire to a grounded
metal part of the car’s chassis. If you cannot find an existing bolt or screw
to fasten it to, drill a hole in the metal and secure it with a screw. To ensure
a good ground, remove any paint or grease from areas where the wire will
contact the surface.
6. PARKING (Pink) – Connect to negative parking brake wire. This wire
MUST BE connected in accordance with federal, state and local laws. It is
the end-user’s responsibility to make sure this wire is connected properly.
7. ACC POWER WIRE (Red) – Connect to a +12 volt circuit that is only live
when the ignition is on. The best connection point is at the car’s fuse block
at the “RADIO” or “ACCESSORY” identified terminals.
8. LEFT FRONT SPEAKER (white, white/black)
9. RIGHT FRONT SPEAKER (gray, gray/black
10. LEFT REAR SPEAKER (green, green/black)
11. RIGHT REAR ( + ) SPEAKER (violet, violet/black)
12. FRONT AND REAR RCA OUTPUTS
13. CENTER RCA OUTPUT (Gray) – The center output must be connected to
an external amplifier for 3D or 6-CH mode.
14. SUBWOOFER RCA OUTPUT (Blue) – The subwoofer output is available
in all sound/audio modes.
15. DEDICATED DVD OUTPUT – Video output for rear screen and left/right
audio output for headphones.
16. AV1 INPUT
17. AV2 INPUT
18. VIDEO OUT (Yellow) - V. SEL output for rear screen.
Or you can go to link below for the manual page 4
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/VM9510_DOC_OM.pdf
Good Luck and please rate 4 thumbs for the free answer
Mar 31, 2010 | Jensen VM9510 Car DVD Player
My sony tv stars blinking 5 times in a row, then the picture goes black for a second comes back then goes black again and it keeps doing it non stop
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
Nov 11, 2009 | Sony KP-53XBR200 53" Rear Projection...
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
59 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
