Question about Zenith Z32H96R 32" TV
FUZZY TV WHEN TAP ON CABLE CONNECTION CLEARS UP REPLACED ALL CABLES
    Scholar:
  • 92 Answers
Cold solder in the tuner is the most likely cause. If the cable connection is not directly connected to the tuner (goes through an input board) then it's probably bad connections on that board.
Certainly seems to be a problem internal to the TV. If you don't have soldering skills you probably won't be able to fix yourself.
Posted on Oct 06, 2008
Sansui sled2453 bad reception
If all the channels are fuzzy it is still a connection problem or a signal problem. replace the cable that runs from the box to the TV. What type of cable is being used? If you verify that the cables are good then you need to call your provider as to why the signal is so weak. The fact that the menu comes up means nothing in this case.
Mar 26, 2014 | Televison & Video
JVC 42" Tv has cut off and when it came back on
If using a cable box try connection direct without the box---also try to remove power from set and box for a while and then power back.
Dec 03, 2012 | Televison & Video
Fuzzy picture on tv 54in
Check your coaxial cable connection and inspect it wiggle it while the set is on if the problem clears replace the cable. Check to see if the male connector that sticks out the back of the set isint loose to the point where it moves when you touch it. If it does you need to have it looked at by a tech usually this problem can be solved with a little soldering but could get more complicated. Depending on the age of the set the fluid in the CRT's gets old and cloudy and light cant shine through it makeing your picture appear fuzzy. Your local tech should be able to change the oil in your set. Finally you could have some bad filter caps but I doubt it.
Jun 12, 2010 | Akai PTH5498 54" Rear Projection...
My vizio tv works fine with the dvd and the wii, but when hooked up to the cable it is fuzzy and picture flashes. I unhooked cables and replaced all of them as well as replaced hdmi cable. The picture...
Ur Main Tuner signal board have problems,that cause of this.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for the replacement.
Mar 20, 2010 | Vizio VW42LF 42 in. LCD HDTV
I have the tv and i have the cable channels but they r fuzzy
Do you have a vcr/dvd player connected to this tv? Make sure it is off. Do you have a cable box? Make sure your TV is on channel 3 or 4 and the same for the cable/satelitte box. Make sure you have good grounds on your cables and rca jacks. Should be easy to correct this.
May 01, 2009 | Proview PA-32JK1A 32 in. LCD Television
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
HDTV has fuzzy picture
Greetings blueberrie,
Many times the cables that you are using can contribute to picture quality. You will want to utilize the best connection possible, in most cases HDMI or component cables. Also, you may want to invest in a line filter, sometimes known as a surge protector. Many of these items are able to control the inconsistencies in power your unit receives, giving you clean power, which will influence picture quality.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 23, 2008 | Televison & Video
Static on cable tv/vcr comb
ok,normally the cable connection that in deployed in the home is only good for 2 tv.and if you add for one,it will become fuzzy. I could suggest that connect other one cable line
Nov 07, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Trutech T2000-FT ATSC doesnt work with cable connection
Do you know how to make a separate VCR work on it? Do you have to push a button or what??? Thanks.
Aug 28, 2007 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
29 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
