Question about RCA L32WD14 32 in. LCD Television
Picture & sound shuts off
Picture & sound shut off after a few minutes of being on (not the tv itself). A few seconds later the tv turns off. Power indicator light blinks red. After unplugging and plugging back in, tv is on without having to push any buttons. Same result, picture & sound, then the tv shuts off, red flashing power light.
  • Anonymous Nov 03, 2008
    sounds like what my problem is
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
After running for a few minutes the picture abruptly shuts off and turns back on for a few minutes then shuts off. This cycle repeats itself over and over.
Make sure the top and back of it are not dirty or obstructed, it sounds like it is overheating and shutting down to protect itself. Or your main power board is going out.
Nov 29, 2015 | Sceptre 32 X320BVHD 32 LCD TV
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Mine does the same thing but it also shuts itself
These usually have a good Warranty as this is a Best Buy product. They would be sure to fix it under the waranty if you take it in. They would be able to give you an estimate of repair if you take it in also. They may have a flat fix fee or possibly an hourly fee along with what the power supply or bad part cost.
Usually a power supply problem. 42" is still an expensive TV to replace. May be best to repair.
Blessings,
A/V Guy
Nov 19, 2009 | Insignia 42" Flat-Panel Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV turns itself off after a few seconds, no picture at all
Solutions?
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
RCA L32WD14 32 in. LCD Television Logo
315 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
