Question about Toshiba 62HM95 62" HDTV
Toshiba 62hmx95 buzzing noise .color distorts more as noise gets louder and goes away when noise stops
    Problem Solver:
  • 61 Answers
Sounds like you have a bad color wheel if they tell you it's not available but only with the engine you can get just the color wheel there are vendors just for hard to get parts
Posted on Nov 19, 2008
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
Turn on TV hear a buzzing and then the TV cycles off and on again
Hi,If it seems you are experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.I found it with complete light engine assembly here: http://www.discount-merchant.com/TOSHIBA-2973026206-p/1160068.htm?Click=48173
Apr 16, 2010 | Toshiba 46HM95 46" HDTV
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Humming Noise at the back of my Toshiba 62 dlp lamp is working but no picture
You probably should have the TV looked at by a technician. if your lamp is lighting up then most likely the noise is the color wheel itself.
Nov 17, 2009 | Toshiba 62HMX95 62" HDTV
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
My tv has a lot of red color in the picture
Tt might be the problem with he color circuit board, bring it to the repair shop for repair, or if you can do it do re-soldering to any visual crack at the soldered lead terminal of the components on the circuit board and then try put on to check if the problem goes away?
Nov 10, 2008 | Akai PT5492S 54" Rear Projection...
Re: Want to buy bad light engine Toshiba 62HM95/62HMX95
Greg,
I had the light engine on my Toshiba 52HM95 fail. Sent it to a company Tri State Modules for repair. Got it back as good as new for $249.00. Goto tristatemodule.com. I hope this helps.
Aug 11, 2008 | Toshiba 62HM95 62" HDTV
Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Jul 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Toshiba 62HM95 62" HDTV Logo
302 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
