Question about Xerox Phaser 8200 Laser Printer
Printer error 07.022.44.11597
Can't print or get the message off? any ideas?
    Novelist:
  • Xerox Expert
  • 297 Answers
That error code doesn't show up in the service manual. If it is 07,002.44.11597 then here is what the problem is:
07,002.44: PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic test. Also exercise processes run with the process motor; transfix, drum maintenance and head tilt. This can be caused by the power control board. The process motor may have more than one task initiated. Reset all solenoids and the pressure roller prior to cycling power.
The Process Drive Gears may be worn out and need replaced, or at the very least they may need to be re-timed.
Make sure you plug this printer directly into a wall outlet and not into a surge protector or multi-outlet strip...
Posted on Jan 18, 2009
5 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: DCP-130c error 44 Please Help
error 44 dcp 130/mfc 240/440 etc.:
abnormally high temperature within print head.
You have two choices to TRY to fix it:
1. put in new carts. press menu then start copy b/w then  fourtimes arrow up button (AUB) quickly one after another.
press by help of AUB and OK:
7 - (Ok) 6  - (ok) 4 (ok) then start b/w copy to initiate the carts and let the machine do some power cleaning.
leave the maintenance mode by pressing AUB 9 (ok)  and 9 again.
2. Make sure that the ph is at correct position simply by pressing on it from top (power up machine. wait til ph runs to left side. unplug from power. simpl press onto the ph). replug to power.
If you still receive the error the ph is defective due to bad generic ink and needs replacing.
Posted on Mar 21, 2008
  • 4 Answers
SOURCE: Mecha error 07
Mecha error 07 and 08 are malfunctions of the paper feed pinch motor located in the right side of the paper compartment. The paper feed pinch is the first roller to grab the paper when it feeds into the machine. This error is tricky. I will walk you through a few fixes.
The first fix is to just power cycle the printer and try to reload the paper. Occasionally the pinch arm will end up in the wrong position due to the printer stopping because the ribbon was empty.
The second fix is to check and make sure that the sensor arm is reaching both sensors on the motor. Sometimes the arm binds on the metal plate inside the paper compartment causing it to not reach the sensor.
The third fix is to start replacing parts. The two things to start with would be the sensors and, although rare, the motor itself. After those are ruled out the only other options are the wiring harness running from the sensors to the junction board, the junction board itself, the power cable running from the junction board to the controller board, and then finally the controller board itself.
Posted on Dec 08, 2008
RoryMRP
  • 111 Answers
SOURCE: Printer shows the following message:-
Your error message is telling me that you are running twinax. You might want to check your address selection,cable or t-connectot.
If any parts are needed or if you have any questions please call.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alisp IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 07, 2009
  • 910 Answers
SOURCE: Getting an error message on
Sorry if this is a little vague but this is all I've been able to find in the 30 minutes we get to review a problem.
K102 is a control relay and the error indicates it's faulty.
The only place I've found that may be able to supply a replacement is at the link below although I suspect this would be a job for a printer engineer.
http://www.theprinterplace.net/cgi-bin/fccgi.exe?w3exec=TowerApp&FormName=PartSearch&PartNumbers=062H2734
I'll keep looking to see if I can find any further reference to this relay or a service manual showing its location.
p.s. Model No. is 6262-D22
Posted on Aug 10, 2011
Error message "head open" any ideas why please?
Check the microswitch on the leftside of the print head.
Sometimes a part is missing or the print head is not correctly mounted
Jun 15, 2011 | Toshiba TEC B-4700-I/O-QM Thermal Label...
I have an error message 0060 on my HP Inkjet 8500a Wireless with a error code 0060 message. No idea what to do. Any ideas please
Please perform the below steps..
  1. Power Off the printer.
  2. Power Off the Wireless Router.
  3. Now Power ON the printer and check if error message is displayed. If error still exists, it could be a printer issue and printer needs to be serviced. Call HP for further support.
Jun 13, 2011 | HP Office Equipment & Supplies
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
MFC9420 Unable to Print
i had this error, it ended up being the opc unit, it tends to drift and then the optical sensor does not line up, give this general error , we managed to get one replaced under warranty, but our second printer suffered the same, next your fuser will fail......
Jul 30, 2008 | Brother MFC-9420CN All-In-One Laser...
49.2F80 Service error
A critical firmware error has
occurred.
Try following these steps -
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jul 18, 2008 | HP LaserJet 2420dn Printer
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Error code 1201
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Nov 30, 2007 | Lexmark X4270 All-In-One InkJet Printer
Printer problem
what error message? what did it say?
Aug 16, 2007 | Epson Stylus Color 777i InkJet Printer
Xerox Phaser 8200 Laser Printer Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
