Question about Dryers
I have a Kirkland Signature dryer made by Whirlpool. It is about 2 years old. The model number is SEDS800MQ1. The dryer will not heat. All of the other functions are working, it just will not heat. It was an abrupt change, one day it heated correctly, the next day it would not. I have made sure the vents are clear, so there are no air restrictions. What may be causing the problem? Is this common and what parts should I replace if needed?
  • Anonymous Oct 28, 2008
    i have the same problem too!
    Problem Solver:
  • 7 Answers
Thermal fuse (white in color) or heating element, both can have continuity checked with a volt meter
Posted on Dec 26, 2009
Maybe your dryer doesnt like you...
naw im jsus playen try to clean the filter on top or somethin or maybe suttin wrong with your boiler
Posted on Oct 17, 2008
My Kirkland dryer model # sdgs800jq2 will turn on but no heat
Recheck your model number. It is not coming up on my search but I can give you an answer regardless. The Kirkland Dryer is one of many whirlpool dryers sold under a private label so it can be sold at lower price. It works the same as most dryers. The heat cycle is regulated by 2 components other than the heating coil & timer. They are a thermal fuse to prevent fires and a thermister that turns the coils on not to exceed a predetermined temperature followed by a cool down period until it resets. So the heater is constantly turning on and off. 2 problems can happen. 1) The heater coil can burn out or 2) the exhaust can clog resulting in the dryer over heating and blowing the thermal protection fuse. If your exhaust comes out on top of the house I'd be willing to bet there's a clog just a few inches inside the exhaust outside the house. Some of these require you to cut it open to get at it. Before you do that, get an ohm meter open the dryer housing and test the fuse, thermister, and heater coil. There are numerous youtube video on how to do this seach for them on youtube. Most have to do with continuity. No continuity means the component is broke. For parts, see your local appliance store that has a parts department. Everybody stocks Whirlpool parts. And if worst comes to worst, write down you model number and go to repairclinic.com & enter your model number into their self help section for step by step instructions & video links. Good luck.
Aug 24, 2015 | Dryers
Our dryer (Kirkland Signature by Whirlpool) keeps stopping during the drying cylce and the on/off button is very hard to push on. When we do get it on, it turns off almost immediately. The heating and air...
Do you have a moisture sensor in the dryer? If the lint filter is on the top: the sensor would be 2 metal strips on a black raised piece on the back wall of the dryer. If the lint filter is in the front, chances are you have, but they would be directly behind the filter housing. They are long metal strips. You can check there by sticking your head in (not kidding) and looking forward. If you use fabric softener dryer sheets, these can sometimes leave a gummy residue on the sensor which blocks any message telling the dryer the load is wet and it could shut down or it could run extra long. If the above applies, clean the sensors with an alcohol prep pad (the little things they rub your arm with before taking blood or giving a shot at the doctor's office)-WARNING: DO NOT TAKE AN OPEN BOTTLE OF ALCOHOL to the dryer area. Did you check to ensure the vent is cleared? Always good to make sure your venting is cleared of any lint and debris at least once a year.
Oct 11, 2011 | Whirlpool Dryers
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Our dryer (kirkland signature by whirlpool) quit heating, tumbling, and blowing. When its plugged in you can hear electricity running but nothing happens. the light stil works inside. we have removed the...
soundes to me like the thermal relay has opened. You have to remove the back and check all fuses....some are round some are oblong. remove both wires and test for continuity.
Sep 16, 2009 | Whirlpool Dryers
Ihave a kirkland signature dryer model#seds800jqo dryer runs but
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 23, 2009 | GE Profile DPXH46EA Electric Dryer
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Dryers Logo
411 people viewed this question
Top Dryers Experts
