Question about Ricoh Aficio GX3050 GelSprinter
Ink collector almost full
I get a message that says ink collector almost full. How do I replace it or empty it?
100% agreed with rrrdddrrrddd. In addition:
Go to Menu->System->INK CU Replace. You will get a warning that overflow may occur(and it's really a messy job), reset the counter and everything should be OK.
Posted on Feb 15, 2010
  • 46 Answers
You do want to replace it. Cleaning it is a very messy job.
1. Turn your machine around
2. Facing the back of the machine, the Ink Collector Unit is located behind on the lower left side.
3. Remove lid with the [!] symbol and pull out container.
Posted on Aug 28, 2009
You must replace it. Ink collector unit for GX 3000, part no: 405660, about 30-40$.
Posted on Jan 14, 2009
2 Suggested Answers
  • 32 Answers
SOURCE: how do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
Posted on May 28, 2009
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
The PIXMA MP150. How can I empty ink overflow collector?
You can empty ink overflow collector only if you unzip the printer.The collector is under the purge unit.
Mar 03, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon iP90 printer message: The waste ink absorber is full. How to replace the waste ink absorber?
it is usually a foam pad that has tubes that **** the ink out and the collector may have an issue you may want to replace your printer if at all possible but canon printers are hard to find parts for sometimes
Feb 26, 2011 | Canon PIXMA iP90 Mobile Printer
I get a message waste ink abrorber full
Check your manual for the location of the waste toner collector, remove and empty or replace it.
Mar 19, 2010 | Canon Office Equipment & Supplies
Empty the waste ink
Take the printer to a qualified technician.
He/she can "empty" or "replace" the waste ink collector
*AND* "reset" the printer's internal software, to say that it has been serviced.
Nov 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I find waste ink collector
there no any waste ink collector, this printer have only a pad for waste ink, (you don't need to replace first time indication) only take the printer to service center to reset this indication.
or
for immidiate printing -
just switch off printer from main (power) swtich then push and hold the on key and paper key then switch on from power. (it's work some time in some pixma)
Jun 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I get a message that says ink collector almost full. I cleaned it and i replace it. But i got always the message :"inkcollector is not set. replace inkcollector". What have to do ?
After you replace the ink collector there is a counter you have to reset it to tell the printer that you are inserting a new collector
Jun 09, 2009 | Ricoh Aficio GX3050 GelSprinter
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
What does Waste ink near full mean
When the printer cleans the print heads it draws ink and disposes it to a foam collector in the base of the printer. Frequent cleaning via software causes this to to become saturated. To my knowledge it cannot be emptied or replaced easily and it is essentially the end of the printers life when full because the excess ink has nowhere to go and cakes on the print head. You can confirm with Canon or check the manual for replacement instructions.
Dec 08, 2008 | Canon Office Equipment & Supplies
Ricoh Aficio GX3050 GelSprinter Logo
4,304 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
