Question about Mitsubishi WD-62525 62" Rear Projection HDTV
KEEP GETTING CODE 37
Keep getting a code 37. No power to the fans, i have put power to the fans and they work just not with the tv. I was told it was a problem with the caps. on the power pwb board so i got a v26 power pwb repair kit had the caps. changed and put it all back together and i STILL get a code 37 any more suggestions?
  • mvick Oct 07, 2008
    where can i find this part and how much does it cost?
  • 61 Answers
From your description Code 37 means either DMD board deffective or lamp fan stopped.so in your case fan is good I would suggest replace light engine.because DMD board is the part of light engine.
Part number # 915P026010
Posted on Oct 06, 2008
  • Sunny Valiplackal Oct 09, 2008
    sorry for delay.
    I think Part number which I wrote previously is incorrect.Light engine is costly.
    May be you can check with andrewselectronics.com or call C.S at 800 274-4666
    with correct model number. Part name is Light Engine.
Mounting amp to car
make sure you mount where you can get a good ground and where it can get enough air to keep cool. underneath the car seat is where a lot of installer put the amp, and if you are going power up a lot i would think about mounting a fan to blow air on it to keep it cool. i have fans connected to my laptop power supply transformer to keep the unit cool, here other ideas you will never be told, putting little holes around power supple, fan area, any where there a lot of heat is generated the air flow helps it stay cooler while powering up the amp.
good luck and be safe rod
Mar 01, 2014 | Volfenhag Car Audio & Video
Mitsubishi wd60735 code 37
A 37 error code means one of your fans is bad. It would either be the DMD fan, or the lamp fan. Take the back cover off of the set and tape down your lamp safty switch. Turn the TV on and see which fan is not working, and replace.
May 17, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Trying to program my sentry big universal remote to my phillips magnavox tv but it keep telling me to put in the code dont know the code
Most of these universal remotes have a method for searching for the tv - they also have a list of possible codes that you can try. Did you do any of that? You should be able to get a copy of their user guide off the internet if you don't have it anymore.
Nov 30, 2010 | Sylvania LC370SL8 37 in. LCD Television
Need a remote code for the Olevia TV for the Comcast remote
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
Jul 09, 2009 | GE JASRM24912 Remote Control
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62526 - Error/repair code
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Oct 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
RE: Mitsubishi 52525 still green light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Code for Vizio tv
Go to the VIZIO site - they post codes. Try these for Cox:
0030 or 1758 or 0178
Dan
Nov 15, 2007 | Zenith ZEN700 Remote Control
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
