You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code...
(More)
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code for the mother, it says invalid or cannot be used. Does it matter if I duplicate digits??? example code: 2311
we have had a gemini security system but have not installed it. Then, the baby in the house pressed...
(More)
we have had a gemini security system but have not installed it. Then, the baby in the house pressed on, but no one had a code. it has been going on repedely.
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I...
(More)
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I can't figure out how to open the control panel. Thanks a lot for the answer, Mike
