Question about LG enV VX9900 Cellular Phone
Installing a env screen,
Okay, well just the other day (oct.5) i bought a new env screen off of ebay because my friends accidently crushed my phone screens. it should be arriving soon so i need a solution quickly. I have a general idea of how to do the replacement but i think i need some help, tell me what i need exactly and what i need exactly to do. i would really love for someone to help me soon!
Check this web page out:
http://howardforums.com/showthread.php?t=1257681
Posted on Oct 06, 2008
My screen in candy crush is stuck on get rewards, i have shut down the phone and restarted, i have reset the phone. nothing has worked
Hi Teresa!
A friend of mine recently had a similar problem.
Try un-installing and then re-installing the Candy Crush app.
It fixed the issue for my friend.
Let me know if it helps!
Jun 25, 2015 | iPhone Apps
Cant put picture into computer
I will advice you follow the procedure below,
1.Plug one end of the USB adapter into the phone, and the other end into an available USB port of your computer. Look to the bottom right of the screen and you should see an "Installing Driver..." window pop up. Wait a few minutes to allow the computer to look for a driver for your phone
2.Look for a window to pop up that tells you "Driver was successfully installed." If it never comes up, or instead a window pops up that says "Driver was not successfully installed," it means your computer did not recognize your cell phone. In this case, you'll need to look for the driver. If it did install, skip ahead to Step 5.
3.Install the driver by double-clicking on it. Before you do this, make sure your cell phone is unplugged. After you've installed the driver, plug in the cell phone, and it should be recognized
4.Go to "My Computer." Look for a new drive that has either the brand/model of the cell phone in the name, or simply a picture of the cell phone on the drive. It will probably have the drive name F:, I: or G:. Double-click on it.
5.
Go to Start > File > Settings > Folder Options and select to enable hidden files and folders to be shown. Then go back to your cell phone's folder and look around. You should see a folder with the name "Pictures," "Photos," "images" or a similar name. Double-click on it, and you should see all your cell phone images.
6.
Select images and right-click "Copy." Then go to your desktop and create a new folder by right-clicking and selecting "New Folder." Open up this new folder, right-click and select "Paste." Your images will then be copied from the cell phone to your computer where you'll be able to access them any time.
Take care.
Jul 28, 2010 | LG enV VX9900 Cellular Phone
Dont know the security code for my lg env
Hi, my name is jeff and I work for a used cell phone and repair store in Sioux Falls South Dakota called THE CELL PHONE GUY. How you fix this problem is take your phone, Dial ##77647269900 select service prg. hit okay on the esn screen when it comes to the next screen enter in your phone number. the last four of your phone number will be the unlock code. let me know if this helps you, i love the feed back
Mar 17, 2010 | LG enV VX9900 Cellular Phone
My chocolate only flashes to the verizon wireless screen
Verizon allows you to recieve a warranty replacement device for devices not purchased through verizon at a 50 dollar cost, Some representatives from verizon do not know this and you sometimes have to remind them to look in their M&P's which is their method and procedure page to find policies if they are still reluctant make sure you request for a supervisor. And also by policy water damage can only be determined by corrosion on the device (which rarely ever happens) and the sticker is not used because of the fact that humidity it self voids that sticker. I hope this helped with your problem if you need any more Verizon help let me know.
Mar 02, 2009 | Verizon Communications LG enV Cell Phone -...
My husband bought me a motorazr v3
page 69 on the lock feature have u tried that?
Jan 04, 2009 | Motorola Mobility RAZR V3
Orange LG EnV(VX9900) Cell phone problem
From description , it looks like a faulty display ribbon connector. The phone must be taken apart, and probably the part replaced to fix this.
Well that happens on Ebay, you pay less than RRP, but it is difficult to get guaranty cover.
My suggestion:
Ebay offers paypal cover up to $500 if you open a dispute with the seller within 45 days from purchase.
Go to Ebay, if you are still in time open a dispute immediately (even if they suggest contacting seller first), as time is running out.
After opening the dispute, contact the seller , explain the situation , and see if he want to give you refund, otherwise ask Ebay full refund through dispute resolution.
Oct 12, 2008 | LG enV VX9900 Cellular Phone
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Cracked screen
I've had my enV for about a year, now. within the first month, I cracked its screen. I have both insurance and a warranty for it, but Verizon is unimpressed-- they suggested that I either purchase a new model, or perhaps buy the enV 2. it's whatever.
Feb 28, 2008 | LG enV VX9900 Cellular Phone
VX9900 Random Restarts and Blue Screen of Death
I was told by Verizon that this is caused by outdated software. If you have the software upgraded it should fix the problem.
Jan 10, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
