I have recently upgraded to Lion on my Mac (regretfully!) Now my Samsung laser color printer will not work, have searched everywhere for drivers and Samsung will not update four Apple Lion. Does anyone know of a generic or common driver that can be used, this printer cost me a lot! Thank you. Ian
Gutenprint and Gimp Print for Mac OS 10 2 through 10 8 and later
SOURCE: Driver for Mac OSX - Samsung SCX-4x16 Multi Function Laser Printer
doesnt look like it is supported by that model.
System Requirements
Before you begin, ensure that your system meets the minimum
requirements.
Supported Operating System
• Windows 95 OSR2
• Windows 98/Windows 98 SE
• Windows Me
• Windows NT 4 Workstation or Server with Service Pack 3
• Windows 2000 Professional or Advanced Server
• Windows XP Home edition or Professional.
Minimal Requirements
• Disk space: 300 MB for installation
• Memory: 64 MB
• CPU: Pentium II 233 or higher
• Required software: Internet Explorer 4.01
SOURCE: No printer driver for Samsung CLP 315 to use with Mac Os 10.5.6
Didn't I just answer this...?
...well, here we go again!
You find all drivers (including Mac 10.5) here.
Enjoy!
SOURCE: Cannot get brother hl 2040
Normal 0
Normal 0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: need driver for latest mac os for samsung 1610 printer..
go to samsung.com and go to drivers and downloads or support then search for samsung 1610 printer drivers to download
SOURCE: Need a printer driver for Samsung SCX-4720 for apple mac
OK, this answer might actually help you!
We just had the same issue with the same printer on 10.6.
Make sure all your OS updates are installed and then go to add a new printer in System Preferences (Printer and Fax section) and hit the "+" button.
If your printer is plugged in and turned on you should see it as a USB printer in the window that pops up.
Select (click on it) that printer one time and then click on the auto select driver drop down and choose to select a driver. Choose the following driver "Samsung ML-6100 - Gutenprint v5.2.3" and hit add. This driver fixed all of our problems.
No thanks to the USELESS Tech Support of Samsung. I despise companies that don't give a **** about supporting older products! Sorry, I'm in a bad mood!
