Question about Frigidaire Refrigerators
Water leaking from bottom of fridge - Frigidaire Refrigerators
  • truthzx95 Jan 26, 2009
    model #glrsf236j water puddling and freezing in bottom of freezer.
  • 61 Answers
Usualy a pluged drain tube , at the raer top of the refrig compartment you may see a drain cup dipending on modle of fridge . if so gently pull staight out from rear wall and clean cup . there is a posibility there is a plugged drain above in the freezer compartment . this will require a service man.
while you have the cup out its a good idia to use a small hose to blow out the drane leeding out the rear and down to the compresor compartment as well ' hope this helped..
Posted on Oct 06, 2008
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
Have whirlpool gold refrigerator with freezer on top. Water leaking continuously out bottom on floor. I turned water valve behind to off. All leaking stopped. Can someone tell me where to look for the...
One big question before you go hunting. Before you turn off the water, was the water running all the time? Meaning if the water had a continuos flow the leak is before the fridge. If the leak is erratic then its on the valve side to fridge.
Follow the water source in the fridge, supply line to water valve (bottom right behind the fridge), from there it should run straight up the back into the freezer. So, if the water is coming from the valve, replace it, if from the water line - replace it. If the water line came off or out of the freezer reconnect and check for a frozen fill tube.
I hope this information helps.
Oct 21, 2013 | Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water lks bottom of fridge ,also ice tastes horrible
u shd spl ot ur wds fly. Do you mean the water leaks at the bottom of the fridge? If so, you may have a clogged drain hose. Pull out fridge, disconnect power, check & see where drain comes out of fridge, go to front and pour hot water down drain to see if it is frozen. It may be clogged (pea or food). If the drain doesn't work, the fridge will leak. Check the gasket on the fridge door for sealing and make sure it is in good shape.
Oct 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
199 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
