Question about Dell Dimension™ B110 PC Desktop
BLANK SCREEN??? I KEEP GETTING A BLANK SCREEN WITH A FLASHING UNDERSCORE AT START UP EVERYTIME. THIS STARTED TO HAPPEN AFTER MY POWER FLICKERED FOR A SPLIT SECOND. MY POWER HAS DONE THAT BEFORE, BUT NEVER WITH THIS RESULT TO MY COMPUTER.
  • 36 Answers
This new system I'm using has done something similar on a few occasions. I only had to disconnect/reconnect the plug from the back of my monitor and did the same with the Vdo card plug and everything was fine. That hasn't happened again since I put a different power cord on it.
Posted on Nov 13, 2008
Screen first flickering then gone blank. Model LA40D550
Please be more precise:
Does this happens after immediately pressing the power button, during booting or at windows start up.
Mar 05, 2015 | Computers & Internet
Asus eee pc not booting
Try to go to BIOS and run a HDD test.
To Go to BIOS turn on the NoteBook and Keep Pressing F2 and you will enter the BIOS set up.
Search for Hard Drive Test Option from the Menus
If the Test Passes then you need to Reload the Windows OS or if the Test Fails you need to get a New HDD
Jul 14, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My fujtsu siemens laptop is not booting from the hardrive and all i am getting in the fujitsu siemens sign and then a blank screen with a underscore flashing when i was on my laptop before i had a virus...
try booting up in safe mode, switch the pc on then keep pressing f8 till a menu appears use the arrow keys to highlight safe mode, then press enter. If windows starts up run a virus scan
Apr 10, 2011 | Computers & Internet
My computer keeps flashing the blue lights on and off,screen blank,not coming on tried to take battery off hold down start button connect to ac nothing happens same problem
Sounds like video card or video cable is faulty or loose. Is screen always blank no matter what you try? Were you getting intermittent screen flickering. There is a ribbon cable that runs from base to lid that sometimes get worn or loose from constant open/close of the lid. Try cranking lid to different positions while trying to boot up. You maybe able to find a video card under one of the covers on bottom. push card all the way inward to make sure it is seated correctly.
Dec 02, 2010 | Computers & Internet
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Blank screen blinking underscore Toshiba laptop after startup
if you can get into the BIOS-setup, verify if your hard drive is recognised as a bootable device and set as first boot device. if the disk is not recognised, you might want to verify if the P-ATA/S-ATA controllers are enabled. if this is all the case, but the problem remains, then your hard disk is probably broken.
Oct 05, 2009 | Computers & Internet
Screen flickering
Does it stop or does the problem dissapear if the brightness and contrast are reduced, If it does, a common problem with the conventional CRT TV`s was the capacitors in the power supply. Basically, they dry out and that`s when the problems start. In some cases if it`s really bad, you can hear the power supply twitching as the voltage starts to drop on the secondaries. Hope this is helpful, Ian
Jul 15, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Dell Dimension™ B110 PC Desktop Logo
76 people viewed this question
Alun Cox
