Question about Whirlpool LGR7646E Dryer
Whirlpool gas dryer runs but won't heat
Hello, I have a whirlpool gas dryer model # LGR4634JQ2, only about 3 or 4 years old, yesterday I noticed the dryer was still going on the cool down cycle, so I opened it and noticed there was no heat either, I tried it on the very hot cycle and it didn't produce heat or advance. We cleaned out all the lint that was trapped inside back left of the dryer and we checked the vents which have worked until now, and that did not solve it, I was reading about it and I thought it may be the thermal sensor. What do you think my problem may be? Any ideas?
Thanks,
Stella
  • 943 Answers
Hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Posted on Oct 06, 2008
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
Heat won;t turn on
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 02, 2010 | Whirlpool LGR5644J Gas Dryer
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
My dryer wont heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My 4 1/2 year old electric Whirlpool dryer runs
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
My two year old dryer doesn't heat up Anyone know why? Or how to fix it?
I noticed you said it would not heat up and you made no mention it would not run and I assume you paid the gas bill so I would first check for air restrictions in and around the dryer. I would clear the restrictions and then check the duct fuse.a24ab96.jpg
Feb 22, 2010 | Whirlpool WGD5300S Dryer
Whirlpool dryer model LGQ80000JQ4 starts to heat and runs then stops heating, but rest of dryer seems to run fine
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
274 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
