Question about OKI C5200n Laser Printer
What to push when using legal paper
I have tried loading in the bypass try and in the tray and it keeps saying tray is empty....Can you please help????
  • 3 Answers
Load the paper between the guides on the MPT tray push the guides up to the edges (otherwise pressing the blue button won't work) then press the blue button on the right hand side of the paper. QED.
Posted on May 26, 2010
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
On the laser printer HP 3600n it says it needs paper in tray 2. where is tray 2?
The printer comes with one main tray which is referred to as tray 2. The bypass tray is labelled as tray 1.
Jun 01, 2014 | HP Laserjet P3015X Printer
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
The printer is asking to load legal paper in Tray 1 but legal paper does not fit in Tray 1. How can I redirect it to mfp?
Paper up tp 14" long will fit in the paper tray.
Remove the paper tray fully from the printer.
You'll see a blue tab at the rear edge of the tray, this releases the adjustment of the length of the paper tray. Adjust to the size you need, and replace the paper tray.
NOTE when new (and in the box), the printer has tape on the paper cover (at the back of the printer), make sure this has been removed, as it will prevent the paper tray being pushed fully 'home' when adjusted to a large paper size.
If you print a lot on both A4 and Legal size, maybe it would be worth buying a second paper tray and leaving them set for the different sizes you use.
May 21, 2010 | Dell 3110cn Laser Printer
Keeps saying add paper but paper is in legal and letter drawer
Check the display carefully, is it waiting for a different size to be supplied, or is it waiting for apaper to be loaded into the bypass tray
If you attempt to print/copy to a size not loaded into the machine, they will wait for the requested size. (depending on your optional menu settings)
This is especially a problem if you eg. try to print A4 size, and only have US legal or US letter loaded into the machine, and visa-versa.
Dec 09, 2009 | Toshiba e-Studio 232 Black and White...
Keeps saying "Load Tray". Trays are loaded.
I just had this problem when trying to print legal size paper. I figured it out on my own. When you pull the tray out you will see a white tab thing sticking out on both side of the bottom of the tray. If you press these it will release the paper and bring it up to a slant. Push the tray back in all the way and it will print legal size. Who knew? It didn't say anything about this in the owner's manual.
Aug 05, 2009 | Dell 3100cn Laser Printer
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
OKI C5200n Laser Printer Logo
138 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
