Power supply powerspec monitor v30dmbt-u21
Hi we need a power supply for a powerspec monitor v30dmbt-u21. The part number is 6693006610.
  • 1 more comment
  • davezest Mar 09, 2009
    Hi there, I seem to have the same problem. After three years of working properly, I moved the monitor from one location to another in the same room, and the thing has simply stopped working. I called Micro Center, and apart from charging $79 to simply look at it, the chap suggested the power supply is most likely the culprit which would be another $200. I wonder if you found a solution or simply replaced it with a new monitor altogether. I did try the CH UP on the top of the set whilst pressing the Power on button on the remote, to no avail. Your insight would be greatly appreciated davezest@gmail.com
  • pxcorrea Mar 17, 2009
    I have a power spec 30 "TV monitor, and the problem is that the
    monitor does not turn on, replace the cable and will not start,
    warranty has expired and the warranty of 3 years to buy ne micro center
    also expires too,the cost in micro center only to review the monitor is
    $ 69.00, which is very high for me, what can I do?
    I called Micro Center, and apart from charging $69 to simply look at
  • scaton22 Apr 13, 2009
    Same problem....moved the tv, then wont power up...think power supply too.....anyone know where you can buy these parts?
I decided to remove the offending power supply, and searched on-line and found this company:
http://www.power-supply-repair.com/ Tatung HOAU242001 6693006610 power supply for tv Using their services, perhaps I might be able to breath new life into this monitor. Dave
Posted on Mar 10, 2009
I had a problem with that SMPS that was in a Tatung lcd tv. The stand by light would flash and the TV would not start up. i replaced D-2,D-3,D-5,D-48. They are fast recovery rectifier diodes. Replaced all the Electrolytic Capacitors. C-10,C-11,C-12,C-15,C-22,C-24,C-26,C-49,C-50,C-51,C-52 They are 470uf. 1000uf. 22uf. Also replaced Metal Oxide Varistors Cy-1,CY-2,CY-3,CY-5. That fixed the problem and the the cost for parts was $80.00 au. Hope this helps. Cheers
Posted on Jun 05, 2009
  • BeefeaterNZ Feb 16, 2011
    Hi, any chance you may have noted what the IC1 chip on underside of PCB is-this chip and R51 are not able to be identified-IC1 is blown
I too have run into the Tatung bad Power Supply problem. I have been looking around the web and I see that LOTS of people have been having the same problem so, in my opinion, the power supply is a poor design. In any case, since I promised to give this LCD TV to someone (before I knew it was broken), I was determined to fix it. Based on Evil_one11's comments, I changed the following components: C11, C?? (next to C11), C10, C12, C13 - all 470uF 35V, C24, C49, C??, (next to C13) - all 1000uF 6.3V, R12 - 47KOhms, C26 - 22uF 50V, C6 - 0.0047uF 1000V, C52 - 47uF 50V, D8 - fast diode, 1A 100V. After doing all this, the PS came back to life! Now, I did a lot of debugging before I replaced all these parts and I saw that the PS was being overloaded and shutting down. Once it shuts down, it locks up until a cap discharges which takes about 10-15 minutes. My opinion: one of the Caps was probably shorted out and causing the problem. I thought that perhaps the caps did not have a voltage room above (6.3 V for a 5V supply and 35V for a 24V supply and one of them may have blown during a spike in the startup. I raised the voltage of the replacement parts from 6.3V to 16V and 35V to 50V. However, I also replaced R12 because I noticed it appeared burned because it was either under designed (only 1Watt) or it was too close to the main power transistor and it overheated form the transistor's heat sink. I replaced R12 with parallel 100K 2 watt resistors which measured to be 53Kohms. I also think that it is also possible C26 may have been bad and not holding an initial charge to let the PWM controller get started. In any case, it works again so I'm happy. Good luck fixing your own supply. OH, BTW, IC1 is a System General SG6841.
Posted on Dec 11, 2013
My powerspec B324. I start computer. Nothing appears on monitor at all.
If power supply fan doesn't start try another power supply/
Then try that power supply on another mother board to verify that power supply is OK.contact me on tthor@mweb.co.za for further info and advice.
Sep 11, 2017 | Computers & Internet
Have tacken it apart and the power bord is blown where can i cet a now one for it can any one help
I use shopjimmy alot and have had very good luck with their boards. I found it there but its currently out of stock.
I would call them on Monday and see when they might get some in.
Heres the link to the board on their website
http://www.shopjimmy.com/powerspec-6693006610-power-supply-unit.htm
The part number is 6693006610, I also checked on ebay and found pretty much every part for your tv but the power supply.. You can search there using the tv model number and companies are always adding parts there as they get them..
I had no success with any of my parts vendors that carry replacement television parts. None of them carried Tatung..
Shopjimmy is going to be your best bet..
Good Luck!!!
Dec 04, 2010 | Tatung V30DMTT 29.6 in. LCD Television
NO POWER TO TV POWERSPEC TV MODEL V30DMBT TESTED POWER SOURCE AND TURNED POWER BUTTON OFF AND ON
The power supply circuit inside the tv may be bad. Normally a bad capacitor is the culprit. You may visually inspect the circuit (the first circuit connected to the power chord inside) for leaks or swollen capacitor. The entire power supply circuit may have gone bad. Test if there is power coming out of the circuit to verify.
Jun 08, 2010 | Televison & Video
Powerspec 6342 won't turn on
probably have a power supply or motherboard that is dead
Apr 08, 2010 | Micro Electronics PowerSpec 7805 PC...
Power supply problem
As an electronics tech, you should know that replacement part information can only be obtained from the original manufactuer. A public "fix-it" forum is the least likely place for such specific information.
Have you tried asking at the supermarket? Of course not.
Oct 06, 2009 | Tatung V30DMTT 29.6 in. LCD Television
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Computers & Internet Logo
2,539 people viewed this question
David Payne
David Payne
