Question about ViewSonic VX910 19" LCD Monitor
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on by itself for a few seconds and then off again.
  • sooriyashs Nov 28, 2008
    my computer is 5 years . the monitor is HCM770FH model.A few days back it showed ' no signal' when i switched off the computer. usually the screen turns blank and the monitor light turns to orange. it does'nt happen now a days.recently the monitor started going off and switches on on its own.all the while the cpu keeps on working.I tried to change the resolution but its of no use. pl help
  • Bari-Bary May 18, 2009
    With some computers the monitor complains of wrong signal input.With others it works for some minutes then goes off and only comes on again after it is disconnected and left to idle for a while.This is an hp1702 lcd 17'' color monitor
  • 65 Answers
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Posted on Oct 07, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
My car is a 2007 Ford fusion. Yesterday, out of nowhere, my car alarm just went off. I kept pressing the unlock and lock button to make it stop (it usually stops when i press these) but it would not stop...
The alarm is running your battery down. Have you tried unhooking the ground wire from the battery for a few minutes to see if it will allow the electrical system to reset itself? Sometimes cars need a re-boot just like a computer.
Apr 18, 2013 | 2007 Ford Fusion I4 SEL Sedan
Either a loose/bad power cable or the backlight is failing.
Jan 30, 2018 | Sony SDM-HS95 19" LCD Monitor
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
With my Nikon D3000 the monitor is stuck on the info screen. Do you think I need to take it in for someone to look at it?
Probably, but try this sometimes works. Remove the card and every button...remove the lens and put it back on.....leave the camera alone for 20 minutes....insert the battery and then the card....turn it on.
Aug 20, 2011 | Cameras
The language on my menu has changed to Russian. How do I get it back to English
Press one of the buttons on the monitor to activate the OSD (On Screen Display). Wait about a minute -- the OSD probably will cancel itself, if you've pushed the correct button.
Then, use the other "left/right" or "up/down" buttons to navigate through the various settings (contrast, brightness, et cetera) until you get to the "language" setting. Press the "accept" button to select it.
Press "left/right" or "up/down" until 'English' is displayed. Press the "accept" button to choose that language. Then, wait a few minutes, for the OSD to "self-cancel".
Apr 24, 2010 | LG Flatron L1750S 17" LCD Monitor
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Lg flatron w2234s monitor is flashing ??
I am going to suggest if it's only 3 months old you should take it back to where you bought it. Mine quit working right a few weeks after I bought it and they gave me a new one. Be sure you take your receipt with you. Even new things can mess up.
Mar 02, 2017 | Computers & Internet
Digital TV Converter keeps shutting off
The DTA800 has a Power Saver feature that turns the unit off after 4 hours if it is idle (no volume or channel changes).
Press MENU button, press #5 (Setting/Configuration), press #3 (Power Saver) Select OFF to de-activate this feature (no Power Saver).
This is covered on page 11 of the DTA800 user manual.
Apr 25, 2008 | Televison & Video
ViewSonic VX910 19" LCD Monitor Logo
203 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
