Question about Maytag Atlantis MDE7400AY Electric Dryer
When the dryer is on it smells like something is burning
The lint trap is clean and when its on it smells like something is burning.
  • Anonymous Oct 15, 2008
    We just cleaned out the dryer with a vacuum. We'll see if it fixes the problem. but it smells electrical and I have a feeling we'll be calling the repair man. ugh...
IF YOU USE DRYER SHEETS IN YOUR DRYER, YOU MAY WANT TO WASH, BY HAND, THE SCREEN IN YOUR VENT. tHE SHEETS BUILD UP A COATING ON THE SCREEN AND IT WILL MAKE YOUR DRYER WORK A LOT HARDER AND MAY CAUSE THE SMELL.
Posted on Oct 15, 2008
huuum
  • 750 Answers
SOURCE: my dryer smells as if
Kandjmorse,
huuum At your service!
You told me that your dryer smells as if something is burning after running only a minute or 2, and the damp clothes are "smoking" NOT steaming. Vent duct is clean as is lint trap
I find two answers are possibilities for this situation.
1.If it is an electric dryer one of the connecting wires to the element is lose or not snug, and the electricity is arcing across the gape, so you smell a tiny bit of burn.
2. Or the thermostat is malfunctioning and you need hands on service to diagnose and change this part.
DO NOT RUN THE DRYER!
It is a fire hazard!
Sounds like a Thermostat problem to me!!
How old is the appliance?
If the appliance is 10 years old or more it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
And can pay for them selves in only a few years!!!!!!!!!!!!!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 12, 2008
  • 131 Answers
SOURCE: maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Posted on Mar 31, 2008
  • 958 Answers
SOURCE: Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Posted on Jul 22, 2008
lenwest
  • 150 Answers
SOURCE: Dryer won't start and smells like something is burning
Sounds like you have lost your cycle timer or control panel.I would replace it or have it replaced.
let me know
Posted on Feb 17, 2009
  • 10865 Answers
SOURCE: odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
Posted on May 20, 2009
A burning smell inside the drum when I use the gas dryer
The burning smell is usually one of two things. If it smells like burning rubber the dryer belt is on its last leg and is slipping or stuck. If you are a diy'er the replacement of the belt is more time consuming than difficult. If it just a burning smell, then it is most likely lint built up inside the exhaust. You'll need to scoot the dryer out and get behind it to take off the dryer hose that vents from the dryer to the outside. Take off both ends for the most convenient and thorough cleaning. You'll need to blow out the hose with an air compressor and/or push a cylindrical brush through the hose or a rag on the end of a long stick. Be care not to puncture the hose! Once done, you are not finished cleaning. The back panel of the dryer needs to be removed to access the exhaust's internal pathway. You can try to clean it from the lint trap and the place in the rear where the dryer hose attaches, but be aware that cleaning cannot remove all the lint stuck to the exhaust pathway lining. At Home Depot, Lowe's or Menard's they sell brushes on wire, etc to clean the dryer's inside exhaust pathway.
Hope this helps!!
Jun 13, 2016 | Dryers
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
Dryer smoking up house and threw exhaust vent smells like something burnt
Hello, Well the smell is most likely from lint that is trapped in the dryer burning. The first thing you need to do is check the lint screen just inside the door. Second is to take the vent tube off of the back of the dryer and check to see if it is plugged with lint inside of the dryer. Clean out any you can see, also if the tubing inside of the dryer is most likely plugged with lint and the heating element is catching the lint on fire. If let go without cleaning this will cause a fire! I work for an appliance repair company and have seen dryers catch fire due to them being clogged with lint, you have two options; first is to clean it yourself, second is to have an appliance repair technician come to your home and clean it. The second is easier and safer but the first is cheaper but very labor intensive. I hope that answered your question and helped. Good luck!
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
Smelled like something burning, then quit working
clean lint trap out more often after every load and try to vacumn inside lint trap lint tends to slip down below the trap and yes it will ignite from time to time My gas dryer did it once and yours it smoked and stunk but because I was home it never went furtherif you open bottom front panel if your machine has one you can get a lot of old lint cleaned out there as well...and most dryers post in their manuals the risk of lint fires
Dec 18, 2009 | Dryers
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
Burning smell from dryer
you smell lint heating up,when is the last time you had your lint trap,lint exhaust,and wall lint hole cleaned out,that is your problem(very unsafe could catch on fire inside the dryer,let me know-mike
Apr 10, 2009 | GE DVL223EBWW Electric Dryer
My dryer smells as if something is burning after running only a minute or 2, and the damp clothes are "smoking" NOT steaming. Vent duct is clean as is lint trap.
Kandjmorse,
You will be fine
Bless You huuum
Sep 12, 2008 | Dryers
Duet Dryer
pls rate me.
tnx
drcool
Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
356 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
