Question about Danby 22 in. DDW399 Free-standing Dishwasher
Danby portable dishwasher filter stuck
I have a Danby portable dishwasher. I need to take the filter out to clean it, but it won't budge. It says in the manual to just "pull up," but it is stuck. Is there something I'm missing? The filter is pretty clogged with hard water deposits (I bought this used). Maybe I have to spray it with something to loosen it. I don't want to break it, but it doesn't seem to want to come out at all! Thanks, Andy.
    Top Expert:
  • Danby Master
  • 76,070 Answers
If it says just pull up then you do just that, it is likely rusted on.
Posted on Jul 18, 2017
2 Suggested Answers
  • 184 Answers
SOURCE: Danby DDW396 Spray Arm
I HAD THE SAME PROBLEM AND FOUND THAT DOWN UNDER THE METAL TRIANGULAR STRAINER IS THE PORT
TO THE WATER PUMP. FOOD AND PAPER GOT PAST THE
STRAINER AND COVERED OVER THE INLET PORT TO THE
PUMP. IT IS A SMALL HOLE ABOUT 1 INCH IN DIAMETER
MOLDED INTO THE SUMP AREA ON THE RIGHT UNDER
THE METAL STRAINER, THIS REDUCED THE WATER PRESSURE THAT THE PUMP PUT OUT SO THE WASH ARM
DIDN'T TURN.
Posted on Mar 27, 2008
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
Oct 15, 2016 | Danby 18 inch Portable Dishwasher in...
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
Danby portable dishwasher ddw1899wp starts taking in water and then stops working with pre-rinse light blinking. Please help me on this issue. Any answer would be much appreciated.
If the water level sensor does not electrically shut off when the level needed is reached, the pre-rinse cycle will error out thinking that the level has not been reached. That sensor is a float device and probably needs to be replaced...
Dec 28, 2012 | Danby DDW1899WP Portable Dishwasher
My salt light stays on my dishwasher. Where do I buy the salt suitable for the Danby Portable Dishasher? I DO NOT WANT TO HAVE TO PAY ANYONE FOR ASKING THIS QUESTION, AFTERALL, I HAVE PAID FOR THE...
HI,
You can buy dishwasher salt in almost every supermarket. It can usually be found in the section with other household cleaning products such as soaps and washing powders. Make sure you are buying dishwasher salt. Do not use table salt or any other type of salt not designed for use with dishwashers.
You have not been charged for this information ;)
Regards,
BElectric
Dec 12, 2010 | Danby Dishwashers
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Danby portable air conditioner does not cool properly. what do I do?
what temp range are you working with here? are the filters clean? we need to know what Air on temp is and Air off temp.
Jun 24, 2009 | Danby Portable Air Conditioner
Danby 22 in. DDW399 Free-standing Dishwasher Logo
115 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
