Question about Belkin (F5D5231-4) Router
Router stoped working
It seems my Belkin 4-port 54G Wireless router has stopped working. I can connect to the internet hardwired directly through my cable modem, but cannot connect when my two computers are connected through the router. Any suggestions or do i simply ned to buy a new router?
    Sergeant:
    Champion:
  • 334 Answers
Yes new roughter netgear is easy plug in play vs linksys new model u can try hard reset button on back if your router has one still dont afte rthat cheak dns server code if u need one they woulve told u his to at start maby cheak for latest firmware for it if any is out ok otherwise ya get upgrade be faster then belkin
Posted on Oct 06, 2008
Cant connect belkin 54g router to internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Mar 27, 2009 | Belkin Computers & Internet
Belkin 8233 - no routing between hardwire and wireless...
Try to see if file sharing between computers connected to the Belkin is working. If it does not try to update the firmware of the belkin. If it does not work its switching function si defective.
Feb 07, 2009 | Belkin (F5D8231-4) Wireless Router...
Hardwiring laptop
hello!
the number ports are the actual ports at the back of the router where you will plug the cable to connect your computer directly to the router.
to find the network key for your wireless connection, you need to connect your computer directly to the router and access the setup page of your router. You need to go to the wireless settings and get the wireless network key from there.
Aug 27, 2008 | Belkin (F5D5231-4) Router
Network key for router.
In onder to obtain this information you need a computer that has internet connection through the router, if you have a main computer that is wired through the router then use that computer if not try to hardwire the laptop to the router(plug it to any of the number ports that say ethernet/lan). Access the setup page of the router by typing 192.168.2.1(deafult IP address of the router) on the address bar of your browser(i.e. Internet Explorer, Firefox, Safari), type admin for the username and leave the password blank. Go to the Wireless Settings/Configuration tab of the router and verify the security mode(WEP or WPA)
Aug 04, 2008 | Belkin (F5D5231-4) Router
Router
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231-4) Router Logo
61 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
