Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis My Maytag Atlantis makes aloud shinning sound when spinning. It spins fine but loud! Is there a way to tell if it is just the belt?
Mine is doing the same thing. In 2004 (might be 2003 or 2005), Maytag redesigned the insides. They were getting complaints from the Maytag dealers and repairmen about having to replace the bearings on so many of the machines. Maytag redesigned the entire part and paid all customers to have it replaced. My machine had the bearing replace and the entire part replaced. It fixed it for a little while, but started doing it again not long after. I happened to be the bookkeeper for the Maytag dealer I bought my washer from. He was so frustrated with Maytag (along with many others who attended the same Maytag repair schools). Maytag never did recall the product. Only offered to replace it for free and waited out the warranty on these bad washers. They have now gone back to the original "dependable" design, but it does not help us who are still having issues and out of warranty. I never have understood why they weren't forced to recall the product. Or how they could choose to voluntarily replace the bearings until the warranty was out but never have to stand by the product afterwards. This very washer was the demise of the business I worked for. Not only was this struggling dealer having to spend all of his time repairing these washers but customers were no longer willing to by the "dependable" Maytag anymore. In fact, my boss said "So much for the lonely Maytag repairman" like the commercials always say. He visited with many in the same line of business in the smaller towns and they were all struggling also. Many customers held them responsible and began shopping at the big box stores for other brands.
I can't remember what the part was exactly. It had to do with a part that had two bearings one on top and bottom....seems like it was in the transmission.
Posted on Oct 12, 2008
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag atlantis washer(spinning problem)
Your problem sounds like a broken belt . Check and replace. Good Luck Friend.
Jan 25, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Dec 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
No spin
Drive Belt is slipping or has broken.
Dec 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
