Question about Dell Precision M60 Notebook
Power Button Not Working
The power button won't work. It will not turn it on or off. For a while, I was using the button that will take it in and out of sleep mode (when you open and close the laptop button), but I lost power the other day and now it has actually turned off - not just gone to sleep. Is this something I can service myself or is there a solution at all?
  • 2 more comments
  • bonniebendel Oct 06, 2008
    Are you suggesting to remove the top of the laptop keyboard area? I think it is all once piece. Is there an easy way to do this or are there screws that secure it on the bottom somewhere?
    Thank you...I'll have to try that tonight. The computer in the video is different, but I assume it will work the same.
  • bonniebendel Oct 07, 2008
    This worked perfectly. I don't know if it was unplugged or what, but if I squeeze where the plug is, it will turn on/off now. Thank you so much!!
  • Anonymous Oct 15, 2008
    i have had the same problem with the switch not working at all. i am in the process of following the advice on the video - using another laptop to write this - i found that the connector inside the machine had come loose. that's now back in place.just putting it all back together and hope it works now.
    Problem Solver:
  • 5 Answers
Problem was a loose connector. Unit would power up on port replicator, but power button did not function. Fix worked perfectly. Popped cover off just like video showed. Found loose connector. Two minute fix.
A+++
Posted on Nov 11, 2008
  • 63 Answers
You may be able to remove the top panel that the power button is on. trace the wires to make sure there securely plugged in. (do be careful when removing that cover as you can damage the internal components if you are rough with it)
Posted on Oct 06, 2008
  • Exidous
    Exidous Oct 06, 2008
    No there are no screws that attach to the bottom, its just a panel that snaps on and off.
    here is a video that will help you. you dont have to remove the whole keyboard
  • Exidous
    Yes its pretty much the same, thats the best video i could find to best suit your need. Good luck and be careful!
My Fisher Digital Tablet 7.1 completely stopped working, all the applications already in the tablet won't turn on "Google Market" or anything for that matter. Pop ups saying everything has stopped
I AM HAVING THE SAME PROBLEM, MY FISHER DIGITAL TABLET 7.1 HAS FROZE ON THE INTRODUCTORY SCREEN, I HAVE TRIED THE HOLD VOLUME BUTTON DOWN+POWER BUTTON AND STILL DOES NOT WORK, I HAVE HELD THE POWER BUTTON, PLEASE HELP ME! I HAVE ONLY HAD IT 2 DAYS! :(
Jun 12, 2013 | Fisher Digital New Tablet Pc Android 2...
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Was dusting monitor and computer area and now monitor won't come on. Have checked all connections.
I've experienced similar problems and the power button gets dust in it and it stops working. Try 'flicking' the power button to see if it clears it, that's what I do.
hold the power button firmly closed then suddenly release it - I use the edge of my nail to hold it closed.
Jan 18, 2013 | AOC E2343F 23 inch LCD Monitor
The power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
Nov 25, 2012 | eMachines EL133105 Desktop Computer with...
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
Lenovo P650WG won't turn on
I see you write about lenovo and then I see you say phone more details
Aug 04, 2012 | Lenovo Computers & Internet
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Hitachi 50UX58K-V8F001238
    our hitachi did the same thing. It cost us 300.00 to tell us that there were two bad solder joints and they caused a power surge or something.
    Apr 17, 2008 | Hitachi 50UX58K 50" Rear Projection...
    Dell Precision M60 Notebook Logo
    232 people viewed this question
    Alun Cox
