Samsung dlp tv: was indicating need a new bulb change. changed bulb and now will not work.
    Sergeant:
    Champion:
  • 334 Answers
U sure it pluged in all way unplug tv take bulb out look at bulb not broken in side is it re set it in then reset lamp life on tv
Posted on Oct 06, 2008
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
Oct 14, 2012 | Samsung HL-S5087W DLP TV
I have a Samsung 56" DLP tv. was watching and it went off. light on lower front blinks 3 times, when attempt to turn on. Could it be the lamp light?
Does these LED indicator lights that blinks?It is one of the LED light said lamp or bulb?The tv been used alots,and it at lest 2 years.U have not change the tv lamp or bulb to this tv?Change it,life of the lamp it over.
May 03, 2010 | Samsung HLP5067W Television
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My tv is a samsung dlp 5063w I change de dlp bulb and now is working good but from the back of the tv is a loud noise
Ok look my friend..
first i need to know what type of sound is it. like a click or a buzz?
and then here are 3 suggestions.
first clean your TV with some latex globs and a can of compress air try to do it really good try that...
second. check that all the cooling fans are working just fine!
last one. its your color wheel and you need to change it.
here is a link were you can find the part and not so expensive prices!
http://www.discount-merchant.com/PANASONIC-Cooling-Fan-Set-Cooling-Fan-Set-p/1002171.htm
http://www.discount-merchant.com/product-p/samsung-bp96-00674a-cw-enc.htm?1=1&CartID=0
good luck!
Jan 21, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung dlp hl-p4663w
you need to find out what mage it blow to get the tv to work again
Oct 23, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
