Question about Garmin GPS
Battery replacement on a Garman iQue 3600 - Garmin GPS
My battaery is not getting charged, GPs is working with external power.
Posted on Mar 11, 2009
I have a Garmin iQue 3600, I was changing the battery, when opened the unit the switch marked rec esc on the side of the unit flew apart.I need a diagram of how to reassemble it. Thank You
iQue 3600 Undo engl.V.6 Release
Hallo -
I mistakenly IQUE3600 my system 5 at the english version 6 updated, now I have a white screen,
there's nothing more.
Please help
If your IQUE -Problem is not reparabel - I would sale it, for repair my
If your Garmin is beyond repair, I would rate this unit as a spare part for my broken
Buy
Wenn dein Garmin ist unreparierbar, ich würde dieses Gerät als Ersatzteil für mein kaputtes
kaufen
Oct 26, 2010 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
Battery will not get or hold a full charge
Battery costs about $14 from nany eBay stores. search for "ique 3600 battery"
It is replaceable but be careful of the switch on the side when you remove the case. See:
http://www.viewdo.com/now_viewing.php?id=205
Sep 12, 2008 | Garmin iQue 3600 GPS Receiver
Need a new Battery Installed
I purchased a new battery with the tools to replace the old battery. It is a piece of cake. I think I paid $ 15 for the battery/tools and that was shipped to my home. If you're still in need of help. Let me know.
Sep 02, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600
Sounds like a battery problem and I ordered a new battery to see if that will fix the unit.
We will see!
A Sudia
Aug 26, 2008 | Garmin iQue 3600 GPS Receiver
Need to replace memor4y battery in garmin hanhheld gps.Please advise how to. regards George the internal battery is dead on my old garmin gps III , can it be replaced ?
Battery can be replace for around $14 (look at eBay and search for "battery ique 3600"
See this video for insrtuctions:
Aug 19, 2008 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600 - Won't charge at all
There are larger capacity baterys avalable.
I saw several different size baterys reported to fit the 3600 on the web.
I am currently looking for a parts doner 3600. If you want to part with yours.
Thx.
Alex
AlexRands@hotmail.com
Jan 01, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 can not charge thru cradle and car unit but only thru travel charger, using the pin connector (Green light does not appear when using the main connector on ique 3600, although hot sync and...
Solved:Opened the iQue and used a heated knife to cut horizontally into the + pin and it comes like a U, upside down, from the circuit board, and the exterior side of it was broken. Used tiny plastic and sealant in the hollow space inside the connector and soldered thin copper wire (used for exploding dynamite) from the horizontal part towards the exterior.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
GPS Logo
169 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
