Question about Lexmark X5470 All-In-One InkJet Printer
Printer will not copy subject you put in but makes lots of small blocks
I have a Lexmark 5400 and it will not print copy I put into copy...It makes lots of dark lines and small blocks.
Pat DeLoach
e-mail address:deloachh@bellsouth.net
  • deloachh Oct 06, 2008
    This did not help but thanks for trying....We cannot imagine what has happened to the printer....We have used it only about 25 times but the warranty is out and we're out in the cold with no printer.
    Pat DeLoach
  • Lexmark Master
  • 2,794 Answers
Swap it with a different USB cable and see if that makes a difference.
Posted on Oct 06, 2008
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
My printer will not connect for printing a letter or spreadsheets
Has it ever copied properly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer will not print copy put on the glass
You can download the user's guide from Lexmark's link:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 wont print
-uninstall the software and reinstall it again and dont forget to put chek in the boxes of additional softwares., because those are the software for your scanner.
Nov 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series printer
It seems you have some piece of paper in the carrier.
Could be just a very small piece somewhere in it... remove the cover and take a very close look. Check all rolls if they are loose or if something is locking them.
Jul 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Printer5400 will not run with Windows Vista
please can you tell me if lexmark 5400 series all in one printer copy will run on windows ME?.thanks paul.
Nov 27, 2007 | Office Equipment & Supplies
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
