Is there a better solution than calling the manufacturer regarding the Fresh Air Purifier, and its "replace the plate" problem? I also ordered a new plate, and no progress was made. I bought mine privately, so I do not think calling the manufacturer is an option. Anything you could offer would be appreciated.
If you already have replaced a new plate and nothing happens, problem still there. Then you need to clean the unit. Unplugged the unit, take it apart step by step. Check the contact terminals for corrosion.If corroded,use a sandpaper to cleaned the contacts .Clean the filters all three sheats of foam,or you can use vacuum to vacuumed the filters.If you finish cleaning the purifier,try to look in the front panel for the reset button ,near the power button and press it to reset the system. Hope it may help you; Regards, VOTIT
I am a ecoquest dealer and service tech is there anthing I can help with
Even though I have a plate installed, I keep getting the "install Plate" message when I try to turn on the purifier. What gives?
I have a plate installed but I keep getting the "install Plate " error when I try to turn on the purifier or sanitizer. Any suggestions?
1-Make sure the plate is not broken, will display the message
2-there are two contacts on each side of the plate that must make contact with the screen
Do you want us to provide information about replacing the plate ?
Or do you expect us to provide manual
I found this link to get parts for it:
airpurifierrepair.com
Ecoquest can support the product for you as well regardless of who you bought it from.
Http://www.ecoquestintl.com/support/US40135_Fresh_Air_Owners_Manual.pdf
just click this link and do it every thing manually without calling any repair person.its very very easy.
the procedure is given on page number 7 and 8
.read full instructions for better help.
please rate the solution if helped by it.
thanks,
I am aware of this website for repair and parts...i already bought the plate and it still doesn't work...am i doing something wrong? i.e. troubleshooting or is there a repair facility in my area...Bergen County, NJ? I need practical advice to get my money's worth...hope you can help
yes...to both if you can...thanks
i am not sure how this works...i need to know if it is common to replace the plate and the machine still says "replace plate"...please let me know
