Normaly when you open the door the machine should switch off - the pump constantly pumps. I have checked the water inlet etc no problems there.
Many thanks
Jason Hunter
Hi siphoxolo,
I'm Harvey the Master Plumber.
Your problem is: Normaly when you open the door the machine should switch off - the pump constantly pumps. You have checked the water inlet etc no problems there.
Sounds like a bad door switch. It's in the top of the door panel. You have to take the door apart to replace it. Not a job for the average homeowner. You might consider the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
