Question about GE Profile WPRE6100G Top Load Washer
GE profile Clothes washer
Stops after agitating little bit then i move the knob slightly starts agitating again then stops after a while.
I again move the knob slightlly. i have to do this process 2-3 times until I get the full cycle ( agitation, drain, final wash etc.)complete.
Vinod
313-297-5957
  • e88888888l Nov 25, 2008
    I have the same issue...i noiced that the time remaining light changes from 9 to 15 and then it just stops...
Open the front cover...look to the bottom right side of the tub...you will see the drain hose.  Take the one closest to you (not the black one) off and check to see if anything is blocking the black one that is closer to the tub.  I found a bunch of material in there that was blocking the outward flow.  I removed it with a needle nose pliers...then I put the hose back on and it has been working like a charm ever since.  Let  me know if this work.  Good luck...I hop you will be as happy as I was when something as simple as that fixes the problem.
Posted on Dec 14, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
SOUNDS LIKE THE TIMER IS GOIN OUT, NOT TO SURE, BUT SOUNDS LIKE THE CONTACTS ON THE TIMER IS ON ITS LAST LEG, GET THE MODEL NUMBER AND SERIAL NUMBER AND SOURCE AROUND FOR A REPLACEMENT TIMER............
ITS REALLY EASY TO REPLACE..........
GOOD LUCK........
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
What will cause black grease stains on clothes in a GE washer, when the clothes are not greasy going in. Agitator seems a little loose.
It maybe a bit of grease worked it's way down inside the agitator,check if there is a way to "torque" down the device.
Mar 28, 2010 | GE WJSR2070B Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Feb 01, 2009 | GE Profile WPRE6100G Top Load Washer
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
71 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
