Question about RCA D52W19 52" Rear Projection Television
52" rca projecion tv will not come on i broke it down and there is a faint beebing sound comming from the transformer area
52" rca projection tv moel # p52927
  • RCA Master
  • 5,138 Answers
Chances are you have 3 bad capacitors 2200uf 16v cp150/ cp111 is 330uf 35v / cp114 is 220uf 35v they are green with gold writing on them.
Posted on Oct 09, 2008
Audio but no picture on projecion TV. RCA 50 inch.
P52926 If this is the correct model number...you have a bad resistor that feeds the voltage to the filaments of the tubes. But first check to see if there is an orange glow in each tube. This will be the problem if there is no glow. The glow should be see located at the socket where the circuit board is. Otherwise you could have a bad vertical deflection circuit if there is a glow
Oct 23, 2011 | RCA P52926 52" Rear Projection Television
When i turn on the tv 52" rca rear projection the power light goes on and off but it does not turn on.it takes everal attempts before i get picture and sound
Does it make a slight popping or cracking sound ? If so remove the back cover and see if the flyback transformer shows any sign of burning or arcing. It is located on the far rt. hand rear side with a red wire comming out of the top and a black one behind and lower than the red one.
Oct 13, 2009 | RCA D52W19 52" Rear Projection Television
Power light flashes 3 times then nothing
this sounds like the typical bad fly-back transformer that is also known as the high voltage transformer, n=-Not really a repair for a novice so unless you know all of the safety notices with this set please do not attempt this repair as why save 100 bucks for something that could seriously kill you!!!!!
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca p52731wk projection television will not power on
We are available for conference Today and Everyday. Wewill assist you in repairing your set. The Part you need is Transformer 226094. Please joinin conference for part price and location
LOGIN
Circuitcity
Dec 26, 2008 | RCA P52960 52" Rear Projection Television
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
It sounds as if you need convergence circuit repair and re-alignment
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Changing the lens rca 52 in projection tv
ricki your bulbs are prob. ok you have a vertical or video prob these tv's are easy to repair by a qualified repairman...john
Sep 11, 2007 | RCA P52926 52" Rear Projection Television
My 52 in
Chirping is usually a problem in 2 areas of this unit. 1st check 3 legged regultor on the right side of the chassis, also 2 small transisters and 2 resisters near and in front of the regulator. RCA has a kit for this problem, the second is check the horizontal output transister is on a separate heat sink along side of the Flyback Transformer, it shorts and pulls down the regulator power supply.
May 28, 2007 | RCA P52960 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
351 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
