Question about Acer Aspire 5100 Notebook
Menu disappeared Hi, I used to have an extra item, a toolbar to do the settings, whenever I clicked on the cam's icon. Now it is not there, where can I find it? I d be grateful for help, thanks in advance! Krisztina
  • 1 more comment
  • tolkri Oct 06, 2008
    Thanks but it is not the problem. I have done the suggested before, it appears and works, the only problem is that the settings menu is missing, so I can't modify anything! It only functions the way as I set it last time. Any idea? tolkri
    Sorry I was not clear before. So cam works, but menu toolbar s missing
    I think it s called 'utility bar', can t find on my computer
    Genius:
  • 1,124 Answers
Check on My Pc
or
Ckeck on Start >> Programs >> The name of your sotware camera
Posted on Oct 06, 2008
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
Refresh is not on tool bar
Make sure that toolbars like the "Navigation Toolbar" and the "Bookmarks Toolbar" are visible.
  • Firefox menu button > Options
  • View > Toolbars (press F10 to display the menu bar)
  • Right-click empty toolbar area
Use Toolbar Layout (Customize) to open the Customize window and set which toolbar items to display.
  • check that "Bookmarks Toolbar items" is on the Bookmarks Toolbar
  • if "Bookmarks Toolbar items" is not on the Bookmarks Toolbar then drag it back from the toolbar palette into the Customize window to the Bookmarks Toolbar
  • if missing items are in the toolbar palette then drag them back from the Customize window on the toolbar
  • if you do not see an item on a toolbar and in the toolbar palette then click the "Restore Default Set" button to restore the default toolbar setup
Mar 23, 2014 | Computers & Internet
Spanner icon missing
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com) or you preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if dont need any of them you can disable or remove them
Hope this helps.
Dec 09, 2012 | Google Chrome
I erased firefox toolbar
Please follow the following steps:
1) Open Your Firefox Browser.
2) Select "Customize" from the Toolbars Menu.
3) Add New Toolbar.
4) Name the New Toolbar.
5) Add Items to New Toolbar.
6) Add Items to New Toolbar.
7) Show Icons and/or Text.
8) Click Done.
Jun 29, 2010 | Mozilla Firefox
Where is the toolbar? Why did it disappear? How can I get it bck complete with printer???
Are you asking about your browser toolbar? In Internet Explorer, if the menu bar isn't visible click <Alt>. Go to View > Toolbars. Make sure the items you want have check marks. The printer icon is part of the Command Bar. Once done, check the line Lock the Toolbars. This will eliminate the vertical dotted line next to each Toolbar. When you click on that line, the toolbar disappears.
If you are dealing with another application, you need to do something similar. However, the names and location in the menus may be different.
I hope this helps.
Apr 13, 2010 | Sony VAIO PCV-W600G PC Desktop
I have a Logitech C500 webvcam. I cannot get the software to completely load from the cd. It is brand new! I can get the video, but cannot get the mic on the cam to work!
Launch the Logitech toolbar by double clicking the shortcut icon on your desktop
Open the settings menu by clicking the 2 gear wheel picture
Open audio menu and check all settings.
Close toolbar
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer and configure to your chat program
If the software is suspect, download from the logitech webside
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Identify your cam from the picture gallery and click on it to navigate to the support page for your model
Feb 12, 2010 | Logitech Webcam
Hard disk icon disappeared from desktop
To add the hard disk icon back onto your desktop, first click the "Finder" button in the dock. It is the dark and light smily face icon at the end of the dock.
Next, click the "Finder" menu item at the top of the screen and then "Preferences". In the "Finder Preferences" window that opens, click the "General" button. From there you can select what system items appear on your desktop. You can click "Hard disks" to re-add the hard disk icon.
Oct 21, 2008 | Apple iMac 24" Desktop
Firefox bookmarks toolbar menu disappeared
In delicious menu there's a hide and show bookmarks menu
John Lanz (jquery rotating menu)
Oct 19, 2008 | Computers & Internet
Shut down icon
That is a strange problem.
I will help you to create a shortcut on your desktop for that icon, whenever you need to shutdown your computer, just click that shortcut on the icon.
Right click on the Desktop.
Left click on New > Shortcut.
In the Type the location of the item: textbox enter
%windir%\System32\shutdown.exe -s
The -s parameter is used to shut down the computer.
The following two parameters can be used with -s:
-f Forces running applications to close without warning.
-t xx Set timeout for shutdown to xx seconds.
The following command would shut down instantly.
%windir%\System32\shutdown.exe -s -f -t 00
Click the Next > button.
In the Type a name for this shortcut: textbox enter
Shutdown My Computer (or some other name of your choice)
Click the Finish button.
Whenever you want to shutdown your computer, click the shortcut on your desktop that says ShutDown My Computer, and your comptuer will shut down the usual way, the way it used to shutdown.
Actaviosan
Nov 17, 2007 | Compaq Presario 5000 PC Desktop
Acer Aspire 5100 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
