Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
ERROR CODE LE
WATER LEFT IN MACHINE
  • 1 more comment
  • trobeyjohnso Oct 16, 2008
    Error code LE water still in the machine
  • Anonymous Dec 28, 2008
    lg front load fe flashes not draining but leaking out of front of door... help.. cleaned all hose and traps and still not working????
  • charm_nat May 11, 2010
    Water remains in my LG tromm machine inspite of program ending.
    Let me know how to drain it out.
Clean out the pump filter and drain the black tube next to it located in the lower left corner behide the door. You my want to get a rag with bleach and wipe out the rubber seal on the inside of the machine on the inside of the door. I just fixed mine last night with the water not draining because the pump filter was blocked with link and animal hairs.
Posted on Oct 26, 2008
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
LE error code
Hope this helps.
Error Code Condition
Error Code IE Condition Inlet water supply error
Error Code UE Condition Unbalanced load
Error Code OE Condition Drain error
Error Code FE Condition Water overflow error
Dec 16, 2017 | LG WD14311RD Front Load Washer / Dryer
Im getting an LE error code. What is that and how do I fix it? The only repair guy is either out of biz or just wont return calls. Thank you
LE error codes on LG front loads are usually caused by the filter being clogged. Remove the small door on front left of machine and remove the filter Some water will come out . Clean the filter and reinsert it and see if that solves the problem
Mar 08, 2011 | LG WM-2277HW Front Load Washer
LG WM0642HW ALWAYS HAVE (LE)
Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Jan 25, 2011 | LG Washing Machines
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Code LE comes on my washer it is a LG wm2075cw
Symptom Error Codes
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
LE error code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire or a dislodged ball sensor. Good luck!
Aug 19, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
190 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
