Question about Canon imageRUNNER 5570 Copier
Ir5570 losing network connection on sending only
We have a Canon ir5570. The machine is set up to print, fax and scanning(universal send). The machine seems to lose the ability to scan using universal send and must be powered down and then back up. Once, this is done it works, but it immediately within an hour does it again? When this happens printing is not affected, so I know the network still sees it. Any clues?
Thanks,
Mike
  • 3 more comments
  • neps Oct 06, 2008
    Sending to network folder. We have a folder(s) set up on the server. The path is programmed into the one touch buttons. Thanks for reviewing so quickly.
  • neps Oct 06, 2008
    I'm not currently there but, I believe the firewall is on the router. I also believe we are using norton-symantec on the computers.
  • neps Oct 06, 2008
    Thanks, I will check this and get back to you.
  • neps Oct 09, 2008
    The firewall is on the router, the computers are running Norton symantec. Thanks.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you scanning by e-mail or to another computer?
  • Canon Master
  • 2,794 Answers
Is your firewall on the router or on the server? Are any of your computers using Windows firewall, McAfee, or norton security software?
Posted on Oct 06, 2008
  • Tim Babcock
    Tim Babcock Oct 06, 2008
    Make sure the firewalls are off on the computers. It will block the folders from working properly. All firewall should be ran on the router to keep the scanner folders working properly.
  • Tim Babcock
    Tim Babcock Oct 09, 2008
    If they are running Norton, chances are the firewall is block them. On some versions of Norton even after turning off the firewall, I seen problems with the machines dropping off the workgroup.
    The best way to check this is to go to a computer and select network in Vista or network neighborhood in Windows XP and see if all of the computers and folders appear on the network. If they don't Norton needs to be reconfigured.
How do I fax using a cell phone and bluetooth?
Hi Gail
It's a little challenging as you need to configure a few things between your phone and the fax. These steps are basically one of doing it, but, I would resort to using the old fashion way! :-)
How to Fax Wirelessly Wireless faxing is easier today than it has ever been before. Whether you're faxing wirelessly from a tablet, smartphone, or computer, wireless faxing is pretty much as easy as sending an email.
There are three broad ways to wirelessly send a fax:
  • Use your cellular network
  • Use Wi-Fi
  • Wirelessly connect to a fax machine via Bluetooth or your wireless network
We're going to break down each of these faxing options down below and explain everything you need to know about wireless faxing.
Wirelessly Faxing Over your Cellular Wireless If you're trying to fax from your smartphone or tablet, then you're likely going to be faxing over a cellular connection.
There's only one way to fax over a cellular connection: online faxing.
Online faxing services act as a virtual fax machine. You communicate with this fax machine over the internet. That fax machine receives emails for you and sends them to your inbox. Then, you email the fax machine whenever you want to send a fax to a recipient.
With online faxing, there's really no restriction to the number of wireless devices you can use. As long as your device has an internet connection and the ability to send an email, you'll have no trouble wirelessly faxing over your cellular wireless network.
Aside from online faxing, there are no other ways to wirelessly fax over your cellular wireless network. You can't turn your mobile device into a modem. There's also no smartphone software that transforms your mobile device into a fax machine hardware platform.
Put simply, you can't receive faxes over the same number as your cell phone. It's impossible.
Using Wireless Internet (Wi-Fi) to Send a Fax Using wireless internet (Wi-Fi) to send a fax is as straightforward as sending it over a cellular connection.
The best option is to use online faxing. Online faxing lets you send a fax over Wi-Fi as easy as sending an email.
You sign up for an computer fax provider, then send an email just as you would normally send an email. Here's a quick step by step guide:
Step 1) Pick an online fax provider and sign up
Step 2) Compose a new email over Wi-Fi as you normally would send an email
Step 3) In the recipient section, type the fax number of your recipient followed by the online address of your fax provider, like by typing 1234567@nextiva.com.
Step 4) Add a cover letter to your fax by typing something into the body of the email
Step 5) Click "Send" after you've verified all of the information is complete.
That's it! You've just sent a fax over Wi-Fi using an electronic faxing service. If you're only sending a small number of faxes, then you might not even have to pay for faxing - many providers offer free trials or let you send a small number of faxes for free.
Alternatively, if you don't want to use online faxing, then you may be able to connect to your wireless fax machine over your Wi-Fi network (provided you're both connected to the same home or office network).
Some multi-purpose printers (with scan, copy, fax, and print capabilities) will have wireless connectivity.
Both fax machines and multi-purpose printers will also sometimes have Bluetooth functionality, which means you can connect to those devices outside of your wireless network.
Use a Fax Machine with A Wireless or Cellular Connection Some fax machines can connect to your home's wireless network over Wi-Fi, or they can connect to your computer over Bluetooth.
However, some fax machines go beyond this and connect to a cellular network on their own. These wireless fax machines are physical fax machines that have a dedicated cell phone connection.
These machines also go by names like GSM fax machines or CDMA fax machines, depending on the type of network they use.
If you use a wireless fax machine like this, then your fax machine will have a separate fax number and cellular service account. Faxes are sent and received over the cellular network just as they would be received using a traditional fax machine.
This type of wireless fax machine is ideal for situations where you don't have a phone line but have good cell service. These fax machines require a strong cellular connection, as any static or loss of quality on the connection may prevent the fax from being accurately transmitted.
These are all the ways to send and receive a fax wirelessly!
May 11, 2016 | Cell Phones
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Dec 31, 2010 | Canon imageRUNNER 400S Copier
How do I set up the copier to scan and send the files to my e-mail address? We don't have any mailboxes set-up. It is networked and I can print/copy from my desk. Thanks!
Do you have send feature? If you do, go to additional functions, system settings, network settings, and scroll down to e-mail/fax, then input SMTP address and e-mail account set-up for the machine, reboot and you can now sent e-mail.
Oct 05, 2009 | Canon imageRUNNER 5020 Copier
How can I use a networked Canon MX300 to send faxes from my PC?
You can use scan to email. Network or internet faxing is a dud.
You will have to have the software on your workstation.
Aug 18, 2009 | Canon MX300 Office All-In-One Printer
No network printing
you need to add orinter to printers and faxes folder via IP address if you can contact me via phone i can walk you through it
May 11, 2009 | Canon imageRUNNER 3035 Black and White...
Scanning
joslloyd universal send is not available on the 3300 but it is on the 3300i.
You link to an old version of scangear software. Use http://downloads.canon.com/cpr/software/devicemanagement/NWSG_v2.21.exe
On the 3300 press System/Options button, One of four buttons far right, next to copy, fax, mailbox.
Press Online.
Read the manual included with ScanGear for how to set it up. Or ask if you are having difficulties.
Aug 27, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
I want to scan then send instead of scanning whilst sending
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Feb 07, 2008 | Canon FAX-L200 Plain Paper Laser
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Unable to send a print job to the device.
i know what your problem is phone 07764303923
Oct 06, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5570 Copier Logo
408 people viewed this question
old marine
old marine
