Error code le - Washing Machines
    Sergeant:
    Champion:
  • 200 Answers
Hi
Tell me company name and model no so that i can help u..
thank you
Posted on Oct 06, 2008
  • Thafa Oct 06, 2008
    Hi
    check it an 1E error or LE error code..
    If 1E means this the problem..
    it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine.
    If it's LE means
    LE REFERS TO LOCKED ENGINE. SEVERAL DIFFERENT THINGS CAN CAUSE THIS ERROR CODE TO BE DISPLAYED.
    1ST, USING THE WRONG SOAP WILL CAUSE THIS PROBLEM - USE HE SOAP ONLY!!!
    - IF YOU HAVE BEEN USING THE WRONG SOAP, BEFORE CALLING FOR SERVICE I
    WOULD ADVISE YOU TO RUN A FEW SHORT CYCLES WITH HOT WATER ONLY - THIS
    SHOULD HELP IN REMOVING ANY SOAP RESIDUE FROM THE SOAP SENSOR AND BOOT
    AREA.
    2ND, THE CONTROL BOARD MAY BE DEFECTIVE - YOU NEED TO CHECK VOLTAGE OUTPUTS TO VERIFY.
    3RD, BE SURE TO CHECK THE WIRING HARNESS - IT HAS BEEN KNOWN THAT WIRES SOMETIMES BECOME FRAYED AND LOOSE RESISTANCE.
    thank you
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Crosley front load error code LE
LE error code. The machine thinks the door is open. If it's not, then the switch or control board is faulty.
Jun 03, 2014 | Crosley CW6000 Front Load Washer
We are getting an LE error on a LG WT R852 washing machine
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Aug 13, 2011 | Washing Machines
LG washing machine loud and error code LE
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
What does error code LE mean?
heatman101
Sep 20, 2010 | LG Washing Machines
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Code LE comes on my washer it is a LG wm2075cw
Symptom Error Codes
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Washing Machines Logo
Top Washing Machines Experts
