Question about HP DesignJet 1050c plus InkJet Printer
HP 1050c adds small amount to each plot
HP 1050c adds 1/2 inch to 5/8 inch to each plot in autocad (1/4 inch to top and bottom). doesn't amtter the size of plot. we have tried changing drivers. tried reducing paper size. it always adds a little to each plot. two service guys spent an hour on it and could not find the problem. it seemed to happen after a firmware update, but not sure.
  • 2 more comments
  • jdebauge Oct 07, 2008
    We have the same problem where I work... IT has been working on it for a while but the only work around we have managed to find is scaling the print by 97.221% with the page size set to a custom size of 1353mm by 903mm and then we still double check with a tape measure because it only works from 2 of the 7 computers we have... IF anyone figures out what is going on with this plotter please help us...
  • eclipse-me Oct 08, 2008
    typically our margins are set to 0.2" to 0.25" depending on paper size. i have tried setting to 0.0", that didn't work well. we are using hpgdi9.hdi driver. we have adjusted the paper size to a half inch smaller in increments of 0.01 (example-18x12, set to 18"x11.5" and it still plotted 12.5"), adjusted the plottable area. most of the settings are default except for some custom paper sizes. are there some settings your are specifically thinking about that i should check? list them and can say what they are set to.
    thank you
  • steve shroder May 11, 2010
    media type settings specifically must match on the control panel of the plotter, as well as in the driver. also make sure that your print quality settings are set to best in the control panel as well as the driver. Have you ran an accuracy calibration with the particular media type you are having the issue with? if not, then do so.
    have you checked the margins setting in the drivers and the machine control panel? autocad setting can overrule the driver on occasions and do crazy things. also make sure the media profiles are set correctly in autocad, plotter control panel, and driver because these settings directly effect the timing of the plotter. please post again, I'm sure I can figure it out.
    Scholar:
  • 96 Answers
I have seen this problem before. if this is the same problem? have you used this printer and autocad before ? i mean without error? if this is the same problem, we never could get autocad to work properly and had to replace the DJ1055CM printer with a T1100. hope this helps you.
Posted on Oct 01, 2009
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
I have plotter HP designjet 500 24" but when plotting from autocad do not plot in gray color, even though layers as assigned in light colors on the plot style.
You need to set up your pen assignments in Autocad, have you done this? ie, Pen1 is 0,25 black, pen2 is 0,35 blue etc,etc. If this is not done you will have problems with colours and line thickness's.
Jun 25, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
HP Designjet 1050c begins to plot, then stops plotting with the error message "Turn of printer, check printhead path". What is the problem?
you need to lubricate the slide bar with some thin oil ( sewing machine oil).put the oil on your finger and then touch the bar this way you wont spil oil into the printer
Nov 03, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c InkJet plotting issue
Friends,
You doesn't say what application and OS versions you have, or if the printer is shared from a server or connected locally to a workstation. This is signifcant to solve the problem. Please clarify.
To make this work properly, all machines should have the HPGL driver and all drivers should have both the "Autorotate" "Inked Area" boxes ticked - both under General > Printing Preferences > Advanced AND under Advanced > Printing Defaults > Advanced.
Then you should create a paper size that is as wide as the media is wide, and longer than the longest/widest paper size you're ever going to print (6-10 feet long is OK!) - BOTH under Printing Preferences AND under Printing Defaults. This will ensure that every "odd" paper size (within media width limits) is printed without problems.
If the printer is installed on a server and shared, these settings should be done on the server - and the driver should be reinstalled on the workstations. If not, these chanvges should be done on each workstation that has access to the printer over the network.
When using older versions of AutoCAD you might have to reinstall the printer there as well for the changes to take effect.
Note: This solution has worked successfully over several years while working at HP support. The suggestion about the looong paper size may sound strange but it works!
//Al
Feb 10, 2009 | HP DesignJet 1050c InkJet Printer
Scaling drawings automatically HP8100
Check the printer settings and make sure to set the "Fit To Page" option to "None".
Jan 15, 2009 | HP DesignJet 1050c plus InkJet Printer
With IP printing through Novell iPrint the AutoCAD plots partial. What can we do to solve? Set to LPR or toe RAW printing?
usually RAW works.
if you the printer connected in any of the parallel port the LPR (DOS) line print shuld work.
Jan 12, 2009 | HP DesignJet 1050c InkJet Printer
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
1050C plotter
replace the network card, then reconfigure the IP address in the machine and that should take care of you. if not then you could have a bad emod (electronics module). also check the cat5 cable and the network drop for functionality.
Oct 11, 2007 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
276 people viewed this question
Ben Johnson
