Question about Lexmark X85 All-In-One InkJet Printer
Lexmark x85 I have two white gear wheels that have come off my printer. I was having the carriage stall error and when I looked inside - I found the 2 half moon shaped gears. I have the printer mostly taken apart, but cannot find a location for these gears. Do you have a schematic repair sheet you can share? Thanks! Donna
Got it thanx
Posted on Oct 07, 2008
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
On a Lexmark x85 printer how do you unlock the scanner?
Push the red button down that's found behind the printer to unlock the scanner. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 11, 2010 | Lexmark X85 All-In-One InkJet Printer
How do i install it
hiya,
Have a look at this link to lexmark, it will tell you everything you need to know for installing your printer.
Lexmark X85 install guide
Regards
Mike
Mar 24, 2010 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 printer will not scan copy. All three led lights stay on. What is the problems? Open catridge door and the catridge carriage does not move.
This may sound silly, but did you try turning the printer off (and unplugging) for a while (several minutes or more) to see if it can re-set itself?
Jan 04, 2010 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 - one of the plastic gears is broken
go to the website , they might be able to help you out .
click :
http://www1.lexmark.com/products/view/Ink%20&%20Toner/catId=cat10002-category
Nov 30, 2009 | Lexmark X85 All-In-One InkJet Printer
Carrier stall
The most common causes for this problem are:1. The carrage has come unhooked from the guide belt. 2. The guide belt has gotton dirty. On the back side of the carrage is a clear plastic strip with hard to see lines on it. If this has gotten dirty, it can be cleaned with q-tips and isopropyle alcohol. If it has come unhooked, just move it up and down a little in the back of the carriage, it will usually slip back into place.
Jul 25, 2008 | Lexmark X85 All-In-One InkJet Printer
I HAVE NO DISK FOR SETUP FOR PRINTER SCANNER FOR X85
this i presume is a lexmark x85
i presume you have windows xp or vista on your computer
if you have not tried windows setup wizard to install the scanner please do so .if its not listed or found then either go to driversguide.com where you can signup for free and download a few drivers for free or go directly to lexmark
alternatively you could email a seller of an x85 at an online shop/auction site like this link http://peterborough.kijiji.ca/c-buy-and-sell-computer-accessories-Lexmark-X85-All-in-One-Printer-Scanner-Photocopier-W0QQAdIdZ42295454 and maybe the guy might be able to email you the files needed
hope this helps.haemox
Mar 27, 2008 | Computers & Internet
Vista Lexmark X85 printer/scanner compatability issue
vista cant find lexmark X84 drivers on install disks,need replacements
Feb 20, 2008 | Computers & Internet
System error 000 carrier stall Presss power Key
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
Oct 19, 2007 | Lexmark X85 All-In-One InkJet Printer
Lexmark X85 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
