Question about Whirlpool Washing Machines
Whirlpool awm 8500 washing machiene.water not cotinuing to flow in to drawer.checked hoses and filter all ok.one gush of water enters after starting F H comes on and water top closed l e d flashes aftes 8 min.water is definetely coming into hoses.have it since05 never problem.
  • 1294 Answers
SOURCE: Whirlpool washer f30 code
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Posted on Jan 11, 2008
yalmer
  • 552 Answers
SOURCE: whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Feb 07, 2008
Hi there.
We just bought a brand new washer and had the same thing just happen to us. Found out after taking the lid off that the top had pinched down on the mechanism that turns and allows the water to flow in. We were stacking out laundry baskets on top of the washer which did this. After taking the top lid off and touch it it began to move and is working properly now.
Have you tried this?
Hope it helps someone out there in the future if not you now.
Posted on Feb 18, 2008
SOURCE: water gush in power drawer
When water comes out of the powder drawer on spin I think you will finf that the filter is blocked. This sits in the rubber pipe between the drum and the pump. I had the same problem and a half hour with the back off fixed it. A colour catcher was blocking the filter.
Posted on Oct 23, 2008
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
My Whirlpool AWM 8120 front loader washing machine stops after working 6 minute in lcd panel show FH what the problem please ans? tanks tian from indonesia
F/H:
Condition
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Jun 14, 2015 | Whirlpool Washing Machines
Whirlpool AWM 336 won't spin
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 14, 2013 | Washing Machines
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
My whirlpool awm 5125 wont fill up at start of washing
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
Sep 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
The washing machine AWM 5104 does not fill with water, but the spin function is working ok. I have checked the hoses and cleaned the small wire filter.
madam not only cleaning the filter you should check the electric solenoid valve which will be fixed next to the filter. you can check it by giving power supply directly to the valve terminals,if it is working it will allows the water to flow-in or it wont then you should change it.
Aug 07, 2009 | Washing Machines
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal De
