Question about Epson Stylus Photo R220 InkJet Printer
2 red lights flashing
After I try to clean the waste ink pad where is the print head rest, put everything back then I had 2 red lights flashing then printer not working at all. Did download the software you provide still not work. Any help please. Thank you
  • 1 more comment
  • nealpettit Oct 10, 2008
    red lights flasing alternating from one to the other have tried using ssc service monitor
  • Anonymous Oct 12, 2008
    I have the same problems
  • Anonymous Oct 13, 2008
    Yes, when I plugged it in and pressed the on button, the two red lights flash continuouly. The service technition on the phone said to bring it into a service center.
    Problem Solver:
  • 14 Answers
Hi. Usually this happens whenever tehre is an internal problem that limits the movement of the printhead. Try this(although Epson deosnt recommend doing this)... turn off the printer, then try to pull the printhead manually just a little bit to the left then turn on the printer. This may actually free the movement of the printheads, however, this also depends on the nature of the cause of the malfunction.
Posted on Oct 13, 2008
Canon bjc 3010 waste ink error
just clean your cartridge..align it properly when you it back..surely it put properly.
Feb 08, 2014 | Canon BJC 3000 InkJet Printer
Why does my Yellow ink print with a deep green tint on my Epson R220?
The symptoms point to some kind of contamination between the cyan and yellow. Most likely is that the yellow nozzles are picking up a small amount of cyan in the cleaning/resting pad when the printer is waiting to print... it's also possible the printhead has started failing and is allowing ink to mix somewhere before the nozzles...
The former is more likely however, especially if you are able to print a few pages of yellow where the greenish tint/lines fade out to become pure yellow.. but then re-appear after the printhead has rested.
Causes of this problem tend to be a backed up waste ink tube or failed pump.. Again it's more likely the former, especially if you've been resetting the waste ink counter and ignoring pad replacement or redirection of the waste ink.
Simplest solution is to locate the waste ink tube (accessible via the access hatch in the back of the printer) and then flush the tube through using a syringe of warm water (don't use excess pressure). Then fit an external waste tank so that the pad ink doesn't back up again (and solve the waste ink issue at the same time).
Obviously if the printhead or waste pump are failing then you have no other options beyond a new printhead, reconditioned model or new printer.
Hope that helps...
Martin
Dec 01, 2012 | Epson Stylus Photo R220 InkJet Printer
2 lights flashing
What is the flash pattern?
If the red paper light and the red ink light are blinking in an alternating pattern, then you may have a foreign object or piece of paper blocking the movement of the print head. Turn off the printer, open the printer and look for anything in the printhead path. Remove anything that doesn't belong. Some printers have a strip that the print head travels across that can sometimes come out of position. This can be repositioned by moving it up and down as well as forward and back to align in a guide on the back of the print head.
After clearing the obstruction, close the printer and turn it back on. If the error persists, then the unit needs service.
If the red paper light and the red ink light are blinking together and the green power light is off, then the printer has an internal error. Turn it off and then back on. If the error persists, the unit needs service.
One internal error could be the waste ink absorber is full. These pads are below the printhead and absorb ink during cleaning cycles. To reach them is messy and takes disassembling the printer from the top. This may include removing the print head. Pull the pads, blot the ink off them and the places where they fit in the printer. Run clean water over the pads until the water remains clear. Dry the pads (use a hair dryer to speed the process). Then reassemble the printer.
Next navigate to http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp and fill in the model and serial number of the printer (as well as the other required information). You will get a link to download a reset utility for Windows. Run this tool to solve the error. Do not run this utility until the pads are replaced or cleaned; waste ink will get everywhere inside the printer and over your documents.
I hope this helps.
Nov 19, 2010 | Epson Stylus C86 InkJet Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Epson i880 Waste Ink pad location
try this plz dont for get to rate
1. Turn the printer off.
2. Hold down the ink and paper buttons, and turn the printer back on.
3. Within a few seconds, the paper light will start flashing quickly. When it does, let go of both buttons.
4. Within 3 seconds press (and hold) the ink button.
5. Hold it until all three red lights start flashing (about 10 seconds).
6. Let go of everything.
7. Turn the printer off, and back on.
Dec 07, 2008 | Epson Stylus 880 InkJet Color Printer
Printer problam
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them
for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44 etc service manuals, as far as ink pad replacement goes, they are the same.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Sep 24, 2008 | Epson Stylus C43SX InkJet Printer
Canon s400 doesnt print only blinks eight times
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
Jan 06, 2008 | Canon S400 InkJet Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
