,I have a Panasonic NV GS55 using video studio 8 to capture via Firewire. The first time I captured the audio sounded comperterised and on most scenes, there was no audio for the last 15-20 secs of the scene. I tried the same capture on a friends computer and software and it worked first time which ruled out a fault with the cam corder. I then thought there was a fault with the firewire card being a new computer (Pentium 4 3.0 CPU, 848 chipset, 512 RAM) took it back and got them to upgrade the motherboard to 865 chipset with onboard firwire port). The same occurred. I also tried capture using the media player stream capture and the same occurred. Is there a setting for the firewire port? The sound is recording at 16 bit. I am running XP SP2 Home edition on the PC. My friend was running XP Pro. Could the OS be the problem?
Not likely to be an OS problem. And you did the right thing to try a different computer to rule out the camcorder. So we're left with your computer.
It seems like you've got enough power in your computer. But you should shut down any unneeded software to avoid dropped frames that might contribute to your problem. Email, browsers, chat, anti-virus, anti-spam, all that stuff. Shut it down and disconnect from the Internet since you'll be unprotected.
Your Firewire might be the problem. What kind of board do you have? If it's part of an audio card that could be an issue. I've read here (or elsewhere) about some problems. I don't remember any details but a search might turn up something. Or someone with direct experience will help out.
I have a firewire cable plugged in and have the setting to pc accessing, Windows media player...
(More)
I have a firewire cable plugged in and have the setting to pc accessing, Windows media player rewinds and captures the video and then I get error unable to continue with operation.
