Question about Samsung Digimax S630 Digital Camera
Memory Card. Not sure which memory card to buy. Recommendations please.
I have the lexar 512 mb sd memory card and it works perfect for me
Posted on Oct 08, 2008
The camera screen displays "Recording stopped.
I checked with Kodak's pitiful website and it looks like your memory card is too slow. In other words it needs to be able to write at a faster rate to keep up with the camera. Kodak does list the types of memory cards that will work in your camera. I would suggest that you follow their recommendations and buy one of those. The card you have will be fine for pictures but will not work for video.
Apr 03, 2011 | Kodak Easyshare C190 12MP Digital Camera...
I havea kodak M340 and just purchased a 8GB sdhc memory card. I keep getting a message memory card requires formatting. I press OK, get a message formatting ... and then back to the same message, memory...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 18, 2010 | Kodak EasyShare C340 Digital Camera
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    My camera won't turn on. The red-light (between play and delete) button blinks when I turn it on. But nothing happens. Any recommendations?
    HI there please follow the step below & let me know.
    1. Use a fully charged rechargeable battery & remove the memory card.
    2. with out memory card if its working then the card is damaged or virus infected. So please format the card and fix it back. Then try to power on your camera with memory card. I hope your problem will solve them. If not then i suggest you contact with service center. Chances of Lens guide pin damaged/ processor may corrupt. Thanks & waiting for your feedback.
    Apr 08, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
    Pushed the Format button on my L100 Samsung Digital camera and my memory card was erased??? Please explain this?
    formatting the memory card automatically erases all the files in the memory card.
    it's like restoring the memory card to factory settings to be compatible with your camera.
    when you format the memory card using the camera the camera erases everything then creates folders that the camera needs to store pictures in your memory card.
    you can try to look for software that can TRY to retrieve the images but i cannot assure you that this will work
    May 31, 2009 | Samsung L100 Digital Camera
    Memory card auto removing
    Hello There
    # Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    # 2 Open up 'My Computer'. You should see it under the list of available drives.
    # 3 Check its contents first to make sure that you have the right drive.
    # 4 In 'My Computer', right-click on the drive and choose 'Format'.
    # 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    # 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Mar 10, 2009 | Nokia N73 Music Edition Smartphone
    Memory Card required formatting
    Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 26, 2008 | Kodak EasyShare Z612 Digital Camera
    Memory card problem
    please change your memory card...buy new card
    Oct 22, 2008 | Olympus Camedia C-50 Zoom Digital Camera
    Memory card locked
    please help me in unlock my memory card in nokia 3110c
    Aug 08, 2008 | Nokia 3110 Cellular Phone
    3230 nokia memory card not format
    Please consider buying a External Card Reader ... It might cost somewhere around 150- 200 Rs in India.
    Connect your MMC Card to the PC via the card reader and format it by right clicking the drive and choosing 'Format" in My Computer.
    After the Format is complete,plug your MMC back to your 3230 and format it with the Nokia Tool available in the Memory Card option of the 3230.
    NOTE:PLEASE MAKE SURE YOU HAVE AN ANTIVIRUS (Avast Antivirus-Preferrable) BEFORE YOU CONNECT THE MEMORY CARD TO THE PC.
    Product Recommendations : http://www.techcomindia.com/home.php?vaction=showprodd&cat=104&catt=Card_readers&subcat=28&subcatt=External&prodid=623
    Apr 14, 2008 | Computers & Internet
    Samsung Digimax S630 Digital Camera Logo
    32 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
