Question about Sony Playstation 3 (PS3) Console
My game won't eject from the PS3
HELP! we just turned on the unit, first time and all......put the game in and it won't eject, we've tried everything turned on and off....on the front part and the back switch, can you recommend anything else......there aren't even any screws to open the darn thing. When I try to open the disk area there is a white kind of tooth that won't go down, it's like it's locked?????
  • Randy1982 Oct 22, 2008
    Same Problem
  • kripticcc Jan 12, 2009
    The other night i was playing Nhl 09 then when i went to get the disk out it wouldn't let me. I ended up taking the blue ray drive right out. I finnaly got the disk out but the drive is screwed, (wont let me put in any disks). i tried going to many websites for the fix but no luck. Can anyone help?
  • 344 Answers
Hello. The disk drive4 does lock the disk into the drive. The only way to get it out is to disassemble the system and the drive. BUT this will void your warranty. I would advise you to call Sony. Just go to www.playstation.com > pick your region > click PS3 > click support. There you will find some trouble shooting tactics that usually don't work, but there is also contact info for customer support. If you still have your receipt thay will fix or replace the system. I have no idea if they will return your game. If you don't mind voiding the warranty and want to get your game yourself then contact me and I will direct you to a step by step process to retrieve the disk.
Posted on Oct 08, 2008
Game Stuck in console
Try Go to settings and eject it from the inside
Nov 16, 2013 | Sony Playstation 3 (PS3) Console
Ps3 slim not accepting disks !!!!!
Send it to Sony this happened to a friend and they sent it away and came back good as mew
Nov 20, 2011 | Sony PlayStation PS3 Slim 120GB Bundle...
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
Ps3 has madden 12 stuck inside and when i power it up it turns off after 2 seconds.
Is your PS3 hot? If the PS3 system gets to hot I know it has a few issues starting/staying on. Leave it off for a bit and let it cool down. Make sure it's in a well ventilated spot and clear any dust off it and the surrounding area. Then try to turn it on again.
This is a weird fix, but I've read of some people finding success by removing their hard drive and turning the PS3 on without one in. You won't be able to use the PS3 in any meaningful way, but you might be able to eject the disk. Here's a nice guide to removing it. Afterwards put the hard drive back in and hope for the best.
You could also try booting into the recovery console, but if it won't turn on for more than 2 seconds you might not be able to get to it. Still worth a shot though.
1) With PS3 console off, hold power button until it turns on then off.
2) Release power button, then hold again until you hear 2 quick beeps, then release.
3) If, somehow, the console is on at this point, try ejecting the disk.
4) Follow instructions (connect controller), then just try the different options, starting with 1 and working your way down. You should know that option 4 (Rebuild Database) might delete some of your saved data, and option 5 (Restore PS3 System) definitely will.
I've actually gone through the same situation myself when I first got my PS3; I got the disk out by just constantly hitting the eject button. Randomly it worked and popped out, but I was still unable to turn it on for more than 2 seconds. I ended up having to send it in for repair which might be what you need to do. Here's the link to their service/repair website. It's not a fun process; if you're out of warranty it costs $100-$150, and either way it takes at least 3 weeks and you'll lose all your saved data. I remember the questionnaire asks if a game is stuck in the console or not, but I'm unsure as to how reliable they are at returning it.
In case your system is flashing any lights that may be useful, here's a link to what they mean. Not listed is Solid Yellow, which generally is referred to as the Yellow Light of Death (YLOD). If your console has that you're definitely sending it back to Sony.
Hope you're able to fix it!
Sep 02, 2011 | Sony Playstation 3 (PS3) Console
PS3 games won't load
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Aug 19, 2011 | Sony Video Game Consoles & Games
When I turn on my PS3 the light flashes green 3 times then yellow twice then red. It won't eject the game disk. I've tried holding the eject button for up to 30 seconds without success.
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony. North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will not eject the game that is inside
if this doesnt work its broken... this is an override trick b4 you turn it on put your finger over the eject button and hold it there whilst you press the power button once it turns on it should eject the disc, hoped it help
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
My PS3 thinks there is a game in the system and won't let me put a game in, although, there is no game in the system to begin with. Can you help?
press eject a few times if that does not help reset it by holding eject for about 25 seconds then try and put a disc in
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Help please kids gone crazy
Unplug the unit and let it sit for an hour then plug it back in. This will reset everything and should allow u to eject the disc.
please mark this as a fixya!
Mar 09, 2009 | Sony Playstation 3 (PS3) Console
PSP Game Stuck in PS3
1. Unplug PS3
2. Stand up so as you are looking down into the disc opening.
3. Fold out the felt that protects the drive.
4. Look for what resembles a disc. (You should see it)
5. Take to butter knives from your kitchen and with both hands use it like tongs to go into the drive and pinch the disc.
6. Pull out the disc and your DONE.
Worked for me a couple of times.
GOOD LUCK
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
