Question about Marantz CDR631 CD Recorder
Can't finalize disc
I get finished making disc but it won't finalize. It goes from the 2 minute countdown til about 1:47 then back to the main screen like it done but it is not. Sometime it will go from the 2 minute to 1:40 something and then starts to countdown from 4:00 minutes but shuts off about 3:40something and goes back to the main screen. Always have been using maxwell 80 minute 70mb gold audio cds. Can u help/
  • okgb Jan 09, 2009
    the finalize light blinks for a few seconds then goes out , no time is registered on the display , tried a couple discs including the imations
    which worked before , not working
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Clean the laser and use a different [brand] disc. Marantz CD recorders and particularly the CDR631 is very sensitive to disc brand/makes. My deck burns Taiyo Yuden and Mitsui (MAM-A) discs consistently with almost zero problems, but discs like Memorex, ProDisc and a few other cheaper ones can result in a hiccup or two. Also, no problems with TDKs and Imations so far.
By the way, I use all computer-type discs, but if you have problems, I heard you'll get better results using 'Audio' type discs...then what's the point of buying a Marantz "Professional" recorder if you're going to use 'Audio' recordable CDs?
Posted on Nov 09, 2008
    Sergeant:
    Champion:
  • 334 Answers
Wonder if thers firmware update for that model try anther cd just make sure not bad disk ok maxwell reg ones just fone always burn slower then needed also cheak website for firmware updates if avb
Posted on Oct 06, 2008
  • nick helpap
    nick helpap Oct 06, 2008
    try memereox cd-r i meen
  • nick helpap
    also sumtimes u dnt have to finlize it to play on pc see if plays on pc after copy it over mp3 style with wma player ok
LG TV no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 31, 2017 | LG Televison & Video
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Do I just push finalize to finish the burning of the cd?
after you've finished recording press 'finalize' the recorder will then get ready for finalizing and then a countdown time will appear in the display eg '1:20' once this appears press 'play' and the recorder will start to finalize and the digits will count down to zero, once this has finished, your disc is finalized.
Feb 01, 2010 | Pioneer PD-R555RW CD Recorder
CD trays will not open.
Use a paper clip. If you push a wire in the holes of each tray it will release the trays. The proper holes look like little dashes on the face of each tray, one end or the other.
Feb 11, 2009 | RCA CDRW121 2-Disc CD Recorder
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
Finalizing
IF THAT DISC WAS RECORDED ON AND THEN REMOVED BEFORE FINALIZING IT WILL NOT FINALIZE. THE CAMERA LOOSES THE MAIN INFORMATION TABLE FOR THAT RECORDING. ONLY THING TO DO NOW IS, IF THE DISC CAN STILL PLAYBACK ON THE CAMERA THEN CONNECT IT TO A DVD RECORDER VIA THE AV PORT AND RECORD.
Mar 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Disc Finalize stuck at 99%
press OK button on the remote of the DVD to take finalize 99% off the screen , then EXIT button
Mar 01, 2008 | RCA DRC8335
Finalizing Error
You can try finalizing the disc on another machine.Have you tried a different disc? You may have a laser issue.
Dec 02, 2007 | Philips CDR770 CD Recorder
Canon DC100 - Finalizing Problems
thanks I got it plug-in the camcord to the wall outlet with DC adapter then you can start the finalizing thanks again
Dec 30, 2006 | Canon DC100 DVD Camcorder
Marantz CDR631 CD Recorder Logo
394 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
