Question about GPS
My Chrysler navigation joystick is broken how can i fix it
  • 1 more comment
  • adiyeh123 Dec 17, 2008
    my navegation joystick is loose and does not work !! 2005 chrysler 300
  • Anonymous Jan 11, 2009
    Same issue my joystick for my chrysler Navigation is broken
  • JBgolf1 Feb 23, 2009
    Same problem. Joystick does not work on GPS as well as on moving up or down through MP3 CD's. (Same joystick).
I found a source for the sw421 joystick the only problem is i had to order 5 to meet minimum order. I successfully repaired my navigation joystick. Its a 4 axis with push toggle activated switch in the middle. If anyone would like me to repair their unit I will do 4 for $75.00 u pay shipping. It takes anout 1 1/2 hours from start to finish. So the unitcan be back in the mail to you the same day. emericktom@yahoo.com
Posted on Jul 05, 2009
  • emericktom Feb 15, 2010
    I wanted to update my status on fixing these switches. The switch I've obtained is an now an 8 axis switch. The manufacture stopped making the longer pole switch because of all the issues of them going out the new one is about 1/8" shorter. but it still works, and its your only option on fixing the Navigation system bar buying a new unit. The company I get them from has raised my minimum order as well as the price on these joysticks. I charge $125.00 which includes return shipping for the board. I'm available through my cell and can send you pictures on how to remove the board. just send me an email. emericktom@yahoo.com
  • augieee Mar 15, 2011
    Can I get one of these joysticks from you? If so, how much.
    Reply to: Phillipaguilar@yahoo.com
My navegation joystick is loose and no work 2005 Chrysler need one
Posted on Dec 18, 2010
Yellow wrench lights
I would think there is a communication error from the joystick to the controller. One time i had this and one of the plug ends was broken off from the joystick cable. Make sure all the plug tips are straight and not missing or broken on the joystick cable and also on the joystick and controller. it could be a simple fix like replacing the cable, but if you have a broken part in the controller or the joystick ports you will have to replace the defective part.
Aug 16, 2014 | Pride Jazzy Select 6 Indoor Power...
In game characters move automatically
This movement is because of a joystick that is broken. The joystick, while in the netural position, is sending signals to the console and thus moving the character. The only solution is to pull the joystick straight out until you hear a click. If that does not fix it, then the controller is broken.
Apr 24, 2011 | Microsoft Xbox 360 Controller
Need to fix navigation stick for sony ericsson w200i
take to a phone repair shop will probably need new joystick
Apr 15, 2010 | Sony Ericsson W200i Cellular Phone
Sony Ericsson K510i joystick
This is the common problem of a joystick is need to replaced including the keypad and also clean the board ,so it will works better again.
Hope thismay help you;
Regards,
VOTIT
Oct 07, 2008 | Sony Ericsson K510i Cellular Phone
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Joystick broken..
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 07, 2008 | Creative Labs ZEN V Plus MP3 Player
Xbox controller
The joystick breaks when a plastic piece inside breaks. This problem can be fixed using parts from a second broken controller. Open both controller cases, take a good joystick from one (can be left or right) and replace the broken piece in the other. You'll need a soldering iron, solder, and desoldering braid. You don't want to use a desoldering pump as the contacts come off the board VERY easily.
May 28, 2008 | Microsoft Xbox 360 Controller
Where i can find the joystick for sharp navigation system from chrysler 300 , part number sw421
dodge nav joy stick sw 421 are supplyed form company named alps part #rkjxl or rkjxt1f
May 05, 2008 | Audio Players & Recorders
GPS Logo
894 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
